dagga trace
Catch 22
Ha Ha, only joking...., Best will be Bennie or someone up there , maybe even Ht as he has fished up there I think.   our riggs will sometimes differ from yours (Natal vs South Cape vs Cape Town
Ps, I take it you are refering to cob?
Catch 22
I have tried all different fancy styles of riggs for them South Cape bottoms and one rigg keeps on winning the fish and that is your main line,boat sinker and trace, I use it to target all my bottoms in the South Cape, here is Ellaine with a Roman where you can see the trace,lenth etc. Lots of current in the South Cape at times,thus the heavy sinker.
I always try to get my sinker to "knock" the bottom as the boat rocks. Oppie grond.
Catch 22
Length of your trace , well different strokes...I guess.
Here is Nico, look at his short trace.....but it worked.
I like 40-50mm trace-line.
We just use the same trace as for Bek, But I shorten the sinker line that's it.
Generally a 9/0 hook on a 50Lb X 50cm hook snoot and a sinker line of about 70cm of 30Lb. Nothing fancy, big live bait is best like shad or makeral.
Catch 22
Funny how it differs from region to region, live bait comes very much second down here.
dugongboy
This is the live bait trace I use - as a rule live bait is best!!
You can use dead bait or a combo - just add an extra snoot between the swivel and sinker and put the live on the top hook.
Catch 22
3m sinker trace! sheez! Obviously it works for you but heck It sounds bizarre...
Muffin Man
Most of the cob I have caught has been on handlines. In shallow water spots with little or no current we would use light 1ounce to half ounce barrel sinkers with the ends pushed flat with pliers onto the line leaving an arms length of line to tie the hook.
In deeper water the way catch22 described is what we used. You normally fish two lines so your depth can be varied but generally its a phathom up off the deck. I do know of days when the big cob want the bait on the floor in the Southern Cape.
When I stopped fishing with handlines I used a sliding trace. Barrel sliding up the main line, a bead sometimes to protect the knot, swivel and an arms length trace with the hook. The swivel helps when fishing baits that twist in the water. Cheers Paul (MM)
[suB][/suB]
Bux
What if you have a very rocky bottom? How to prevent catching a rockfish every time? Rotten Bottom trace?
