Choka throw bait
roland
The p.e guys will know what i mean by ''bad batch'' .. Atleast got a good pickup on it yesterday. Stuffed with smashed up sards
roland
Need i say, no one told me to clip the sinker on the top hook and not the bottom haha. This was my 2nd attempt. Wanted to slide it but my sinker wouldnt sit. So i changed to a 6oz and chucked it. 20min later i got a solid run but was occupied with the mullets and fiddle stick :(
adam5016
If it was on the beach I am pretty sure about the culprit. On sunday we had 2 rods out with prawn and bloodworm, and a steenie picked up a big tjokka bait on a third rod.
roland
it was a whole choka just missing the head adam.
@ star , i took a walk down kabeljous, sat more or less opp the lagoon
Riaandl
kopstamp wrote:
your bottom hook could possibly where the cable tie is,was.lol that would also secure the bait nicely.
Kopsstamp are you talking about the bend or the eye? I would put the eye of my hook where the cable ties, maybe even lower
kopstamp
@riaandl my idea was tie cable tie the hook just above the bend, then hook will stay proud. but youy idea makes more sense. have found that some times with chokka bait that once the hook becomes to exposed the bites go away, thus if it is slightly higher up one still has best of both worlds.
Riaandl
Kopstamp as jy die tjokka soos volg rig is die hoek nogsteeds proud en steek nie te ver uit nie. net my idee
Roland sorry dat ek jou pic mishandel het
Riaandl
kopstamp
sien wat jy bedoel. net gewonder as daar n paar kleintjie naby is dan eet hulle gou die bene af dan is die hoek redelik oop. maar jou idee is beter.
steve m
i think that where roland put it is right.where you put it should work to but if you put it where you put it it wont stay proud it might twist around or somthing.
i cant realy explain it but in my opinion where roland put it it will get any fish that even looks at it...
im not saying that your way is wrong i just believe that rolands might work a bit better...
:wfish
Brakkanjan
Hi Roland, dit lyk na 'n helse groot gooi-bait. Indien mens so groot bait gooi, sit jy steeds 'n sinker op en watse size?
Ek ry volgende week Natal toe en is nuuskierig.
Dankie vir terugvoer ;)
