Chaps . Nog n ou Lekker probleem vir julle om op t
[color=#006600]Def-e-nition[/color] wrote:
[color=#006600]Mickey[/color] wrote:
Your SL30 reel comes with an internal braking mechanism that consists of two brake collars that fit onto the back of your spool. Are these collars in place? If not, fit them immediately and leave them in. These collars also come in different sizes, so fit longer ones if necessary, or double up with two short ones per side. Do not try to limit your reel's speed with the friction control knob on the side of the spool, but set it to just loose, i.e where there just is a fraction of play if you were to move the spool from side to side.
where are these two suckers and what do they look like ???
hmm , nou het julle my manne .
Where are those two things you mentioned- I've got the box still .
Open your reel up...
The two black jobbies on the spindle arm... those are your brake blocks. You also get red ones which are slightly larger...
Huey
Def
What I'd like to know is the combo of a 13.6 Loomis with the SL30 and say .35(9kg) line going to get me to 100 - 120m mark. I will be only targeting edibles( cob, steenbras and the like)
Def-e-nition
Huey - I sh!t you Not - I am getting that now with my saltist 50 , and If Reefman can hit it on the 30- you should be able to as well . Only thing is that it will require a lot more casting experience ( definitely -being smaller )to do it than with say, a torium , saltist , or grandwave , sl50 . Got it ?
check out my Avatar - the mother of all crowsnests by a pal of mine on my Sl 30 .........   0.55 mm line ..chuckle !
I am Not a believer ofDeeper means bigger fish .
I am after the distance , ESPECIALLY with the 30- as you only use a 4 oz , or 5 oz grapnel , say - then you need the damn thing to be sitting on THAT side of the heavy breaker "white water wash" mark - or you'll be washed side-ways ashore , like what happens to me .
And strangely enough - I Did catch the only fish on sunday because I was casting further , or over the others .
People Bandy 100m about like it's nothing . Im no expert , have a big passion for fishing , being an ex P.E boytjie ( yip - amsterdamhoek se mannetjie ) but reefman will tell you - 100m Is by no means sommer something that just happens .
As you see what I am learning here - fishing is a little more science than I ever imagined , with regards to tackle etc . Very interesting stuff - but once you've got it waxed , Like I have the 50 - you'll have the slightly less experienced fishermen asking you to cast for them , every time .
OR_ you'll find them walking deeper , and deeper into the water , to get their sinker closer to yours !!!! I always laugh when the okes do that !! Hey- we all started off somewhere , even reefman .Ne?
Hey Reef- SHOT for the Photo's - MUCH appreciatte it . I wondered what those darn things were - what you suggest- red , black , or both ?
And oi - HOw do they WORK ?????????????? Does this now put the Spool off balance-make it spool up slower - What ?
Huey
Def
I am relatively new to the sport as well.. Seen some guys wading in to cast,only to a whole lot of salt water in the wader.lol. I have was advised to take out Centrifugal brakes. I dont really get overwinds, even in the dark but want to know from members if they had had any experience with the loomis rod. Thus far my biggest fish has been 10kg apart from seaweed which was heavier! I must say I have used other reels and prefer the SL30.
Def-e-nition
GOT EM !!
Now I just need to figure out whats what and who's who in the zoo tonight ....
jaccil
I love a proper mag breaking system, but I don't use the sleeves on my Sl0sh's - the thumb does the work.
Saltator
Hi Huey
I bought my dad that rod and he loves using it with his SL 30 - casts a 4-5onz sinker miles on the meduim tip. The heavy tip is rated 7onz so you would probably use a 50 size reel with it. Great rod to cast and very versatile.
Def-e-nition
Gentleman . All of you can take a Bow. Holy Crap. REEFMAN - you're a bloody frikkin GENIUS . It's 1.30 saturday morning. Just got back from feeding. I am so tired now of smiling my teeth are gettin Cold. Holy cRAP, this thing can Cast! Loomis Rod is a pleasure to behold. I Finally Cracked it man- my mission i Mean, Not the Rod. To get some distance with the 30. TO SAY i'm blown away by heeding some of the advice given is a mild under statement. The line above at 60 bucks for 600m is an absolute Bargain . 0.4 mm . Check. Medium tip. Check. Brake blocks. Check. 5 oz sinker . Check. 130m. - CHECK ! And this after i was cautious to mate it to my new Rod! The damn Loomis Casts from another Planet. I HAD ONE close call, but as for the rest- 4 hours of casting FULL TILT, AND i didn't Lose a Single Sinker. And i'm just warming up. . . . Tonight i sleep a peaceful and content Man. What a Difference . Compared to tuesday- boys- unbelievable. You can't say it's the same reel. And the harder you push it the harder it Screams! Walt skrops weedeater fluke reefman,you may all take a moerova bow! Now- Walt- i Got something for you. We thought louren's nest couldn't be topped. Check out the image i Post when i Can find the pic on my phone. Words Pale in comparison ! Shit i nearly fell off the rocks taking this Picture!!! Thank you to all of you. Thicker is not always better, as you will shortly See!. . . . . . !!!!
jaccil
I hope those four hours were spent casting with hook and bait into the sea!  Glad you got it sorted. :)  Are you using the clear or red sleeves?
