Squashed a bit and hooked from bottom to top through the lips.
Guys here is a random question regarding my recent visit to the vaalriver where the river is really shallow (less than 2m)... I fish with a long Maxima leader of +-3m 0.80mm. and on a couple of occasions my leader got cut through on something...unfortunately I could not get the fish finder to work so I do not know whats going on...crab...rocks...etc. etc.
Do you guys think a long thin 2m section of plastic coated steel wire as leader would discourage pick-ups?
That is exactly how I normally rig my circles on a carp or muddy head.
I feel you Skuim, but I don't play with bait once in the water and will leave it in till I get a pull. I feel that you have to have confidence in your location where your dropped your bait otherwise you are dammed from the start. Problem here is I get a pull and get cut off underwater...easy thing is to change location but this is not possible where I fish. Anyway, I am back Desember so sal maar sien wat ek kan sort!F1%hpa%te wrote:
Personally I don't like using coated steel but I know off a lot of anglers who use it very successfully. Had the same problem with 100lb braid at the Oranje and I switched back to hi abrasion mono (50lb) and problem was solved. Yes I could see the wear and tear after just one catch on the mono and had to cut those peaces out the whole time but I didn't loose a single fish after that.
Diesel, it didnt look like crabs, but as it is a shallow section...it might very well be!Not crabs chopping you bud?
Yes, I have found to miss a few hook ups when using bigger head baits, but generally I prefer using smaller baits.Capiez wrote:
Absolutely nothing wrong with that but I still believe we are getting it wrong if we move over to the really big baits.
http://www.sealine.co.za/view_topic.php?id=90806&forum_id=64
Is this circle BIG enough for you boys...?Only problem I can forsee with the circles is that you might not have a big enough hook for those big baits as the same size books between the J hook and the circle hooks differ quit alot.
Ja, I know ...Been a bit quiet there kaptein...I have at my recent vaal trip "spiced" my head with cod liver oil and worked a treat.
F1%hpa%te wrote:Ja, I know ...Been a bit quiet there kaptein...I have at my recent vaal trip "spiced" my head with cod liver oil and worked a treat.
Except for my monthly artlure leagues, the rest of my fishing sessions are normally very spur of the moment and/or dependent on my wife's ever-fluctuating hormone levels
Hoop sy's nie secretly op Sealine nie ...
