Solid advice on the 3/spool system for Ultegra 14K,makes perfect sense.
Without digressing,I based the .33mm mono compared to 30lbs braid-assumption on the diameter of the Suffix 832/30lbs at .35mm diameter as per your first post.
If the Berkley Mono cost R200-00 for 600meters,it would then only cost you R100-00 per 300meter topping. Obviously ''durability''plays a role,and only time will tell that of the Mono.
Bite-detection may not be as direct on the Mono,but the ''slickness''may again account for less resistance to side-currents than braid of similar diameter.Fishing the mono off a 50% of breaking strain drag i.e (5kg drag),and adding the ''forgiveness''of ''stretch'' in mono,could make for some interesting results on medium to bigger fish.
Having probably gone totally off-topic here already,I might as well just ponder one more scenario. I suspect it is common knowledge that an overfilled ''braid-spool'' leads to all kinds of havoc when used for spinning with ''light-ish''lures. But I have often wondered what would happen if one ''overfilled'' a braid spool similar to how one can a mono-spool with similar diameter lines,and then use it for SIMILAR application,i.e. baitfishing with a heavier sinker and only making perhaps 10 casts in a session with say 15-20 minute intervals,as opposed to making easily 75-100 continuous casts when throwing lure/plug/spoon.
Again ,thanks for a factually based topic.
