Casting Distance
Ulua
I was out testing rods for casting distance trying to find out the difference in casting distance between different rod lengths and setups (spinning vs overhead). For some land based and boat based areas around heavy surf the extra distance means the difference between strikes and no action.
My test showed that
80m casting distance on Temple Reef GT 80-10 (Pathfinder) Stella 10k SW /SOM 16k spool loaded with JBH 100lbs casting 120g chisel nose plug.
85m casting distance on a Shimano 10ft rod with the same reel and lure above.
100m casting distance with a 9ft6 CD rod and a Daiwa overhead reel and the above lure.
I would really be interested to know what casting distance you guys are getting with what setups...rod, reel, braid and lure.
