Hey bud,
I can speak from experience and say that you wont have an issue with the Freedivers Ali barrels... you need to look at the construction to see why. I've attached a photo but because of the unique design the barrel is way stronger than other barrels... I personally had a 1.4 with 2 16mm rubbers and that thing was deadly!!
I've recently upgraded to Carbon barrels and let me just say that all the hype is worth it... Freedivers have two barrels Xwrap and the maximum length in this barrel is 1.2 with a 20mm rubber but if you want a longer gun or more power you need to get his Strong barrel which is even stronger (my 1.2 and 1.4 is this type) and I've got them with 2 16mm rubbers... there is not a fraction of warp....
so which one you say?
It comes down to costs to be honest, my ali guns where epic and deadly accurate but there will come a time when your finances permits you to go carbon and lets say you wont be dissappointed... my suggestion is that if you ready to make the carbon jump replace the gun that you use the most with carbon.... for me that was my 90cm with 6.5mm spear and 16mm rubber... it's so light and movable, made me a total convert!
