Howzit Eugene. If you understand the way a pr works. the bobbin is simply an object with weight that gets swung around the leader and mainline, releasing line under tension to wrap around the lines. If you attach the line to a sinker and swing that around the lines you get exactly result. And attaching the line to a sinker is quicker than a bobbin, and you can easily select your sinker size according to how much tension you want in the wraps, and according to the diameter (breaking strain) Its already in your tackle box and always with you on the rocks.I always use a sinker. Braid to braid requires minimum 60 wraps, I do 50, Pass the sinker line between braid and leader and then another 50. The pic was done with 60 straight wraps. The braid type, and whether it is treated makes a difference (some don't grip as well as others. The fg is at best less consistent than a pr, sounds like your method would be more consistent. Since getting used to the Pr, I don't do fg's at all. It's also versatile - you can make a loop by doing a pr around the mainline with the tag. Prevents line twist issues.
