I started in freshwater, so grinding comes naturally, old “pap gooierâ€. When I moved to the coast ten years ago I converted to multipliers and stiff rods. Steadily I’ve scaled down on my equipment the last couple of years, smaller reels and thinner (HMG) rods. I always used to look down at the other okes with their dam rods and big grinders, because they obviously couldn’t cast with multipliers. Then I started spinning with my Assassin lite HMG and various multipliers. Spending more time fixing nests than fishing. Now there is a difference between grinder type reels and spinning type reels, they look the same from a distance but they are not. Now with my Poseidon Ultra lite HMG SPINNING and Penn Sargus SPINNING reel, I look like one of those okes, but I know the difference. I use Sufix Performance braid as main line on the Sargus, 50lb, 0.34 mm. Until I installed the Bionic Finger I could not load the rod for decent casts, I figured I did not need assistance in casting as I am quite happy with my grinder casting abilities, I was wrong. Even though I used to cast quite heavy baits into dams, I found it difficult to cast 3-4 ounce spinners with my new rig. I recon it’s the stiffness of the spinning rods that makes the difference, my dam rods would bend 120deg thereby taking the strain off my (mostly dry) trigger finger. While spinning at the coast its quite difficult keeping your fingers dry, making it even harder to control the thin braid.
Casting would not be the same without my BF, it is an investment.
