Blind rivers breaking through
Pslatarix
So guys, its wizzing here in natal, and pleeenty of the riuers have broken through. So my question is, how does this affect the fishing with regard to targeting kob specifically, with all that brown water. Thanx gents.
zulu-X-treme
Well the most important effect would be the change in salinity... Unfortuantely the scary part is the addition of pesticides, fertilizers, unknown chemicals and raw sewage in an otherwise previously stable environment. There's also the massive addition of top soil which can dramatically change the a rivers depth and in some cases even it's shape.
Salinity defines the relative proportions of seawater and freshwater found in different parts of the estuary. Areas close to the oceans have higher salinity, while areas that are closest to river inputs have lower salinity. Salinity is the concentration of salt in water, usually measured in parts per thousand (ppt).
Salinity also affects chemical conditions within the estuary, particularly levels of dissolved oxygen and dissolved inorganic phosphorus in the water. The amount of oxygen that can dissolve in water, or solubility, decreases as salinity increases. The solubility of oxygen in seawater is about 20 percent less than it is in fresh water at the same temperature. Phosphorus, which sticks to particles in freshwater, is released as salinity increased. In tidal freshwater or low salinity reaches of estuaries, dissolved phosphorus is not readily available and tends to limit phytoplankton production.
Salinity affects the physical structure of estuarine waters and influences patterns of circulation. Because salt water is denser than freshwater, layers of different salinities can form resulting in stratification of the water column. Stratification impedes mixing in estuaries, and exacerbates problems such as low dissolved oxygen at the bottom.
http://web.vims.edu/bio/shallowwater/physical_characteristics/salinity.html
Anything that happens to a river in its catchment can have an impact on the estuary. A river flowing through farmlands can become polluted by pesticides, herbicides and nutrients from fertiliser. Soil eroded from badly farmed or overgrazed lands will also be washed into estuaries after heavy rains. This excessive silt load has the effect of filling up the estuary and in some cases resulting in the estuary mouth closing. Silt smothers animals and reduces light penetration so that plants are unable to grow except in very shallow water.
* Bad catchment management is the major cause of estuarine damage in southern Africa.
* The numbers of many important commercial (e.g. prawns) and angling species (e.g. kob, grunter, perch) which rely upon estuaries are dwindling as a result of disturbed estuarine environments.
http://deltaenviro.org.za/resources/envirofacts/estuaries.html
One regularly hears the figure of 300 000 000 tonnes of topsoil being lost annually from South Africa through rainfall erosion, and this basic statistic is then repeated in the form of an enormous area of land so many millimetres deep, or representing so many average-sized farms washed away annually; or the statement is made that it represents sufficient sediment to fill a line of ten tonne trucks parked bumper to bumper and girdling the equator eight times. This type of statistic is mind-boggling, but the author wishes to point out that it represents neither the complete truth nor the best manner in which to obtain the desired reaction.
http://agriculture.kzntl.gov.za/publications/production_guidelines/conservation_farmland/cons_farm_1.5.htm
zulu-X-treme
Just to add, it would appear that it's a good thing in respect to fishing...
During periods of low flow (e.g. estuary during dry seasons or drought), the sea’s influence becomes dominant, resulting in the estuary becoming increasingly saline. Under extreme conditions, the salinity in an estuary can even become higher than that of seawater due to evaporation (referred to as hypersalinity). Prolonged periods of these low flows could also cause premature closing of certain estuary mouths and/or longer periods of
mouth closure.
During floods, most of the saline water in an estuary is flushed out to sea and the entire system usually becomes fresh.
Floods also influence the sediment dynamics of an estuary, which in turn influence the following estuarine features:
● depth and shape of an estuary (Bathymetry),
● distribution of sediment types (e.g. mud versus sand), and
● state of the mouth (in temporarily open/closed systems).
● As many as 100 species of fish are wholly or partially dependent on South African estuaries, while up to 400 species frequent estuaries at some time of their lives.
Common estuarine fish species include kob, white steenbras and stumpnose that grub in the sediment for mud prawns, sand prawns and molluscs. Shad, leervis and sharks are
predators that hunt other fish. The most abundant fish in estuaries are often mullet which are detritus feeders. Most fish that occur in estuaries breed in the sea. Large numbers of their juveniles return to the shelter of estuaries where they mature until they themselves are able to breed.
Estuaries are therefore important nursery grounds for many fish. Some fish, such as the sand goby and the needle fish, are dependent on estuaries for their entire life cycles.
Pslatarix
Once again, great info there mate. Thank you once again. Do bigger fish hunt around these mouths that have 'broken through'? Or would the amount of fresh water put them off? My thaughts would be that the predetory fish, ie kob and sharks would hang around waiting for the bait fish to get washed into the surf. What are your thaughs or experiences?
zulu-X-treme
YUP! I have to agree with you, it's as if all that fresh water and activity makes things happen. Sharks aren't to worried about the salinity, they have been recorded kilometers up river mouths. As for the Cob, you can't go wrong that is exactly what they like, all that ginger beer coloured water...
Here's a quote from Nemesis concerning the Tugela River... "Well at the moment it's a pretty good time to fish Tugela. More specifically South Bank. The river is flowing quiet strong, and when the North Easterly is blowing the dirty water reaches the South Bank. This is when the guys are smashing the Shad, Kob, a few Rays, and alot of Juvenille Hammers and Spinners. The Zambezies have been around and I've also seen a few Blackfins Jump".
http://www.sealine.co.za/view_topic.php?id=46155&forum_id=1&jump_to=631054
Here's a listing of possibly all the River Mouths in South Africa and Sealine discussions related to them, enjoy...
http://www.google.co.za/custom?num=100&hl=en&newwindow=1&safe=active&client=pub-1072729738596575&cof=FORID:13%3BAH:left%3BS:http://www.sealine.co.za/%3BCX:sealine%3BL:http://www.sealine.co.za/mvs/sealine122.jpg%3BLH:50%3BLC:%230000ff%3BVLC:%23663399%3BDIV:%23336699%3B&adkw=AELymgUPQDTAwloEpwD5NtA_2_axh9MWflRJwfednv53frNFqsqHX5PWAC3T5qP74oNQ23Ls2Mwid_0iifVEggKWYryVDji_JDsLie_Yu_sM8dbjZWOxXfYv4pL9ReuQPqzxBWDv6QJbMlXib6BlBtacyp4pG_ZBUP80gkxAeyfL35WMPAi1NpkhgNYq6TxNxPXn1TC5oItE&channel=5009259630&boostcse=0&cx=partner-pub-1072729738596575:drznkt-pnpb&oe=ISO-8859-1&sa=X&ei=9s4vTu7sEZC7hAfx4NEd&ved=0CA0QBSgA&q=river+mouth+fishing&spell=1
Pslatarix
Thanx a stack Zulau x. I now feel confident in my theories. Lol. Mana for you boet. Ima give southbroom point a bash. Handles big swell and the water is a nice brow colour. Maybe a rag bag. . . . Mana for you. @BIG BEN. Da moet altyd een slim manitjie wees. J was seker innie A klass gewess. Sharp chirp tho. Lol.
