Well the most important effect would be the change in salinity... Unfortuantely the scary part is the addition of pesticides, fertilizers, unknown chemicals and raw sewage in an otherwise previously stable environment. There's also the massive addition of top soil which can dramatically change the a rivers depth and in some cases even it's shape.
Salinity defines the relative proportions of seawater and freshwater found in different parts of the estuary. Areas close to the oceans have higher salinity, while areas that are closest to river inputs have lower salinity. Salinity is the concentration of salt in water, usually measured in parts per thousand (ppt).
Salinity also affects chemical conditions within the estuary, particularly levels of dissolved oxygen and dissolved inorganic phosphorus in the water. The amount of oxygen that can dissolve in water, or solubility, decreases as salinity increases. The solubility of oxygen in seawater is about 20 percent less than it is in fresh water at the same temperature. Phosphorus, which sticks to particles in freshwater, is released as salinity increased. In tidal freshwater or low salinity reaches of estuaries, dissolved phosphorus is not readily available and tends to limit phytoplankton production.
Salinity affects the physical structure of estuarine waters and influences patterns of circulation. Because salt water is denser than freshwater, layers of different salinities can form resulting in stratification of the water column. Stratification impedes mixing in estuaries, and exacerbates problems such as low dissolved oxygen at the bottom.
http://web.vims.edu/bio/shallowwater/physical_characteristics/salinity.html
Anything that happens to a river in its catchment can have an impact on the estuary. A river flowing through farmlands can become polluted by pesticides, herbicides and nutrients from fertiliser. Soil eroded from badly farmed or overgrazed lands will also be washed into estuaries after heavy rains. This excessive silt load has the effect of filling up the estuary and in some cases resulting in the estuary mouth closing. Silt smothers animals and reduces light penetration so that plants are unable to grow except in very shallow water.
* Bad catchment management is the major cause of estuarine damage in southern Africa.
* The numbers of many important commercial (e.g. prawns) and angling species (e.g. kob, grunter, perch) which rely upon estuaries are dwindling as a result of disturbed estuarine environments.
http://deltaenviro.org.za/resources/envirofacts/estuaries.html
One regularly hears the figure of 300 000 000 tonnes of topsoil being lost annually from South Africa through rainfall erosion, and this basic statistic is then repeated in the form of an enormous area of land so many millimetres deep, or representing so many average-sized farms washed away annually; or the statement is made that it represents sufficient sediment to fill a line of ten tonne trucks parked bumper to bumper and girdling the equator eight times. This type of statistic is mind-boggling, but the author wishes to point out that it represents neither the complete truth nor the best manner in which to obtain the desired reaction.
http://agriculture.kzntl.gov.za/publications/production_guidelines/conservation_farmland/cons_farm_1.5.htm
