Sorry, JJ i dont agree with you on this one, the bleading wire is a lot harder than the normal carbon coated, i think the grade stainless might be higher, as it does not kink as easy as the carboncoated steel, the coulour is irelevant, and tends to catch more anglers than fish, as for the purple wire, i'm sure hooked would take a few rolls from you.lolI'm gona start my own company and we gona make purple bite trace & full metal jacket fishing wire... I will add R140 to the price of the normal carbon coated wire" what by the way is not carbon as coating on the wire in the first place" wHOOO I'M GONA MAKE LOTA MOOLAA.... They just change the colour and charge u extra for it.... If a bronzie can bite through carbon coloured 210lb wire,then the red colour in the 210lb bleeding wire wont stop him from biting through that to...... WHO WANT'S TO BY MY PURPLE WIRE, Buy now while stock's last (any one) ? Ha ha Lol.
It might not be of higher quality just maybe the bleeding wire cord's arnt as tightly platted to gether in one unit when in the manufacturing proses as carbon coated, so when biten down on the wire actualy space's out and make it harder to bite off indivdualy.... I dont knw?.. But one thing is for sure why pay more for bleeding wire if carbon coated work's just as well.. Granted u will get bitten off on the carbon coated by a machine Nunu if the angile is right, but who say's he wont bite through the Bwire as well... Some time's even 400lb wire get's bitten through by huge fish .. And as for it tieing easily then it must be softer? I tie carbon coated 220lb wire on to bite trace's, mono to wire by using back to back figure of 8" it's difficult to tie but one get's use to it"...JJ Pienaar wrote:Sorry, JJ i dont agree with you on this one, the bleading wire is a lot harder than the normal carbon coated, i think the grade  stainless  might be higher, as it does not kink as easy as the carboncoated steel, the coulour is irelevant, and tends to catch more anglers than fish, as for the purple wire, i'm sure hooked would take a few rolls from you.lolI'm gona start my own company and we gona make purple bite trace & full metal jacket fishing wire... I will add R140 to the price of the normal carbon coated wire" what by the way is not carbon as coating on the wire in the first place" wHOOO I'M GONA MAKE LOTA MOOLAA.... They just change the colour and charge u extra for it.... If a bronzie can bite through carbon coloured 210lb wire,then the red colour in the 210lb bleeding wire wont stop him from biting through that to...... WHO WANT'S TO BY MY PURPLE WIRE, Buy now while stock's last (any one) ? Ha ha Lol.
ya maybe in water 30m deep or more but lot of R&S guy's dont cast far enough to reach that depth and even of some rocky point's... Any way for shark's u dont have to warry about them seeing the wire, they dont care much if they in a feeding mood.. When i fish for flatfish i like going with 120lb wire ..1) for more movement of the bait" as the thick wire can hamper with free movement of the bait making it look un natural ". 2) flatfish can some time's feed shyley in clean water and some time's bite better on thinner wire 90lb or even strait mono... But in discolourd water or at night it dont matter much..I was under the impression that the colour red is not as visible at water depth due to most of the colour except blue being filtered out. Am I right?
you are spot on, red will be one of the first colours to dissapear when you go deeperI was under the impression that the colour red is not as visible at water depth due to most of the colour except blue being filtered out. Am I right?
It will only become black when all colours are filtered out. No colour is completly filtered out at the depths we are normally fishing at.Brand wrote:
I may be wrong here, but when a colour disappears, the item doesn't become invisible/transparent, it becomes black.
Yes i do ...can one use the bleeding wire to make a bite trace??
