1. Best option, take it off and use a casting glove or a piece of Elastoplast around your finger.
2. If you want to persist then make 40 or so casts at a short comfortable range till the release becomes automatic and well timed.
Tips for Using the Breakaway Canon aka Bionic Finger.
a. Wrap your leader around it a minimum of 2 times, preferably 3 times
b. Don't crush it or hold it in with maximum force, minimum finger tip pressure.
c. Set it up on the rod so that it is under the tip of your index finger and not under the joint of your finger.
d. Release earlier and when the rod is pointing upward at a 45 degree angle.
[flash=640,480]http://www.youtube.com/v/kxVBVqyxGaE[/flash]
