BEACH TROLLEY
hrogers
Forgot to do a update on my beach trolley
I found inflatable wheels that are used on trailers.
Work much better that the golf trolley wheels.
The 1st time i test it was a disaster as the crate act as a scarper
I lifted the crate and my problem was solved !!
Work nicely on thick sand and run very smooth an hard surfaces specially on the sand next to the waters !!
JeandlH
Do you guys think this will work on the beach?
Just for the record, this is not my trolley, I got the photo from Facebook.
willem wikkel spies
remember
it is not the width of the wheel that matters.
it is about the ball shape on the sand.
you need a even surface arch type to displace the weight of the trolley.
also you want the wheels to run on top of the loose sand.
flat tyres has a bigger resistance.
the buildup of sand infront of the wheels will make life difficult for you.
pushing is way much better then pulling.
the tubes surfboy is using will be much better.
the roundness of the tube will work great!!!
how long they will last is the question.
lets see, he might walk for years without any flats.....and then might get flat tubes, twenty to the dozen
surfboy
bigger diameter/radius of wheel easier movement.
the inner tube can be pumped to any pressure.... low or high....I use reasonably high....to give a more balloon effect.....I carry a small collapsible bicycle pump in my bag. I used heavy duty lorry wheel valve extensions and located the valve on the face of my wheel.
THAT'S MY BEACH TROLLEY
MADE OUT OFF GALVANIZED STEEL PROFILE FRAME
24" BIKE WHEELS
2 LIVE BAIT BUCKETS
SPACE FOR A CHILLY BIN AND FISHING BAG
ROD HOLDERS WILL BE ATTACHED AS SOON AS I WILL FIND THE SWEET SPOT FOR THEM
I'LL TRY AND POST MORE OPERATIONAL PIC'S
