Onderstaande is n artikel wat Chris n tyd gelede geskryf het vir ESA,aangesien hy ook intensief betrokke was by die daarstelling van die ''length to weight conversion table'' van die soutwater visse.Die relevansie is net so van toepassing op varswater visse as soutwater visse.Peusel solank hieraan.
Uiteraard gaan ons geliefde babers nie net n SMS weg wees nie maar dit gaan letterlik n muis-kliek weg wees wanneer jy die lengte invul in die converter wat ons gaan ''sticky'' hier op die forum.
MEASURING FISH
The calculation of weights based on fish lengths is the result of years of research by many dedicated scientists and research institutions such as the Oceanographic Research Institute, the Natal Sharks Board, and others. This research was summarized into a format that can be easily accessed and used by all anglers. ESA partnered to bring you a way to get this data anywhere, instantly. What can be easier than
sending an sms to get the weight of your catch? All you need to do is send an sms in the format of ESA:species:length to 35010.
Separate the keyword ‘ESA’, the species’ name and the length by a colon
). Also, don’t use any spaces anywhere in your message. For non-edible species such as sharks and rays, you can specify the sex by adding (f) – for female or (m) for male after the species name. If you don’t specify the sex, and there is a difference between the conversions for males and females, the female weight will be returned. The length should be quoted in centimeters, and you can separate decimals by a point. The system recognizes over 1400 common names and different spellings for the 270 species for which there are conversions. If the system does not recognize the name you entered, or if there’s a spelling mistake in your message, you’ll receive a message stating that the system couln’t find a match. Check your spelling and try again!
You’ll receive a return sms in seconds stating the weight of your catch, the measurement it’s based on (either fork length, total length, pre-caudal length or disc width), as well as the size limit (SL), bag limit (BL) and closed season (CS) for the species.
How accurate are the weights?
Accurate measurement is the first step in ensuring that the estimated weight of your catch is accurate. Always measure in a straight line, not over the back of sharks, rays or skates!
As mentioned, the weights are based on the most current published scientific research. There are, however, a couple of factors to keep in mind.
Firstly, fish, like humans, can have different weights for the same length (yip – you get fat fish and thin fish too!). Typically, scientists doing research on fish would measure and weigh large numbers of fish and plot the results on a graph. A typical length-to-weight distribution graph for a species would be similar to the graph below. The dots represent the length and weight for an individual fish, while the line represent the combined average growth curve for all the individual fish weighed and measured. From this average line, an equation is calculated, which is the basis for the length-to-weight conversion for the species. Obviously, the more data (individual fish) are available, the more accurate the conversion will be. The process of refining conversions for the less common species is an ongoing process. The more data we can gather on actual weight and lengths for these species, the more accurate the conversions will be. It’s noteworthy that through the efforts of the South African Shore Angling Association, South Africa is far ahead of other countries in getting length measurements established as the basis for points allocation at the competitive level. Also, nowhere else in the world will you find such an innovative delivery platform like the sms system ESA brings you! Another world first for ESA!
Weight
Length
Other factors that have a more obvious influence on the accuracy of the weights are the condition of the fish (sick vs healthy), and whether the fish just had a big meal (for example during the sardine run when fish gorge themselves with easily available prey!).
The last word on accuracy is that it really doesn’t matter all that much. We need to make a mind-shift change from thinking in terms of weight to thinking in terms of length. But it’s nice to know the estimated weight of your prized catch. You probably won’t make the same impression on your non-angling friends around the braaivleis fire when you boast about your 209cm pre-caudal length raggie! But you’re sure to impress when you quote the weight at 176kg !!
What to do if your fish’s actual weight differs significantly from the weight returned by the conversion?
If you do catch a fish that you are able to both measure and weigh, and the returned weight differs substantially from the actual weight,
let us know! The more data we have available, the more accurate the returned weights can be. Tell us about it in an e-mail to
chris.shoreangling@gmail.com
http://www.shoreangling.co.za/#top#top
