Baber stokke
Skuimkop
Dagsê almal.
Ek is in die mark vir baie goeie en sterk baber stokke. Ek is nie seker oor die lengte nie maar sal skat 8 ft is seker in die hak. Wie kan my help sodat ek die regte stokke koop. Ek sal die stokke ekslusief gebruik as ek vir die 20 kg plus baber klas gaan so hy moet punishment kan vat. Ek sal hom dan ook van 'n boot of inflatable/ kano wil gebruik. Ek sal my PENN katrol op hulle gebruik.
Enige raad en advies sal waardeer word.
Marthin
Skuim van die kant af is daar vir my niks beter as een van die ou Blue Marlin fibreglass 11ft shad stokke nie.
Van n boot af sal ek kyk na van die duurder shimano stokke. Ek ken nie die name nie maar daar is n spesifieke een wat ek al gesien het by fishing specialists. Dis so 8ft heavy spinning outfit. Hy behoort ou snorre se kop te kan draai.
Check out post 17 on this thread
http://www.sealine.co.za/view_topic.php?id=37990&forum_id=29
The jade Axe is designed for fishing for catfish.  I have 2 in the warehouse going at a very special price for sealiners.  Can be used with vertical jigging reels (Spin type) or solid multiplier.  Has a good parabolic action so you can lock the drag and the rod can bend under the boat if a big Cat dives under.
Made for direct pulling and for handling big baits.  If your'e interested send a PM and we can chat.
J
Sounds like a great rod Enigma :)
I recently got a Shimano Crucial 7'6" Heavy paired with a Shimano Calcutta 100b reel spooled with 15lb berkley big game, used it for the first time two weeks ago at Rhenosterkop and the cats where thick, the biggest I managed to pull out of the grass was 9.5kg. I wouldnt suggest the reel for catching 20kg+ from the bank though as you will probably get spooled, I was on a boat and that 9.5kg made some nice runs taking line with the drag almost locked.
As for the rod, you get the feeling you could pull the plug out of the ocean with it.
Biggest Catfish I caught with the precursor to the Jade Axe was a 37kg Cat below Bloemhof with a Reizan Catfish.
Caught it of a 2 man rubberduck using 50lbs braid. Broke my braid on 2 other bigger cat's trying to keep them out of the trees.
Now fish the Jade Axe with 80lbs Whiplash as I'm targeting a 40kg Catfish every time I go out now and they have the power enough to break 80lbs, using an Icon VJ reel from Alpha Tackle with 15kg drag
TOE 007
why not Try one of the tigerspecial Beastmaster rods from Shimano , the ones with the browninsh blank , 7.6 , cork grips , i have nailed yellowtail on them and love them to bits , got 3 of em , you might have a problem casting big baits , but the rod will not fail , oops i just read your post again , and on second opinion you might have a problem when fishing snaggy ponds....
8'6 berkley big game rods , we used in the orange river with no problems ....
Skuimkop
Thanx guys, I've decided on two Jade Axe 10 ft rods for casting and two red bayliners as boat rods and when I take the baits out and were space can be a issue.
Raait nou dat die stokke uitgesort is, wat van die katrolle? Ek het 'n PENN 500 Jigmaster en 'n Shimano TLD Star 20/40 op die oomblik. Ek geniet die PENN meer as die Star so ek sal vir my nog een gaan koop om die Star vir my rock & surf te hou.
Ek is nou opsoek na 'n kleiner weergawe van die PENN of Shimano wat ek op die bootstokke kan gebruik en vir close range hengel so wel as vir small edibles vir die rock & surf wat so minimum 200 - 250 meter lyn kan vat.
As ek groterige kunsaas met hulle kan gooi sal dit 'n bonus wees.
Het iemand enige voorstelle?
