[b]StructureScan[/b] (Lowrance LSS-1) certainly do
willem wikkel spies
john,
this idea might work better then the towfish.
but will 1 still have a problem with the swell height?
surely that should also screw you around.
seems like there aint no perfect world.
live with it, or without.
ss
Al
John,
What about Structure Scan for locating bait? I recall that you mentioned that you could even tell the difference between Shad and Mackeral. Can you show us some examples please and explain how to interpret the images.
Secondly, my intended use in Rivers and Estuaries. We have seen the amazing detail in fresh water for Bass fishing but how well does it work in rivers where we often have a layer of fresh water on top of denser salt water?
pc750109
Hi Fishton
My HDS 8 unit has a cable spilt into two....a power cable and a data cable for NMEA ..?
I know what to do with the power wires.....::S
What is the NMEA for? do I need to use it?
I'll be connecting a lss-1 and sonic hub to the unit
Thanx
Pieter
wille jan
Hi. Pls can any one help me. I want to plot all my gps "marks" on a chart on my pc. Where can i get a program for my pc to do this. I am not so clued up like you. PlS help. thnx
pc750109
Help Please
Spend the whole day installing HDS 8 , LSS-1 and Sonic Hub. All fine except for the Sonic Hub, Noticed that the fishfinder does not pick it up. Tested for power to unit - all fine. Found the power light on the Sonic Hub unit does not light up.
Why ??? Could it be faulty out of the box? or an I missing something?
Fishton
pc750109 wrote:
Help Please
Who did you buy it from?
wille jan
Ok. I found the box, but the cable does only have a "sig lighter" tipe plug on the other end for interface capabilities. How do get around that to down load all my data onto my pc?  I already installed the software you sugessted.
wille jan
Hell I am stupid. Just paged through the manuel and saw that the pc cable is an optional eccessorie. I just hope that our local commercial marine will have it in stock. Thank any way.
Gone.fishing4
:::S Fishton I have this unit on my boat but need to get more Familiarize with it on how this work, know you posted this a long time ago but need first hand assistance with this.
GF4
Fishton
Hi Gf4,
Please post some pics of your installation as well as a couple of screenshots of when you are out on the water.
John
