Awa-Shima fans?
shuraj
I use to fish with teh soft cast , what a fantastic line and very low memory .
The problem is that the line is not stockled at all tackle shops.
HennieB
Craig when will the Browny carp be available in SA? http://za.awa-shima.com/index.php/monofilaments/carp-monos?start=6
shuraj
i know Johan Dunn in Pretoria used to stock all Awa shima products , does anyone know if he still trading.
Rest of Pretoria
Solomons
SA Hengel
Piets Hengel
Dolphin Fish and Camp
Leon's (Both shops)
Tacklemania - closed currently will be opened shortly under new management and all Awa-Shima lines will be available there
Fishing Pro Shop
Ultimate Anglers Experience
MJ Angling
Might have missed a few, we deliver to them weekly so if they don't have what you are looking for then they can just order for you and we'll deliver.
The classic competition is the soft cast upgraded from NT50 copolymer to NT70 and in parallel spooling making have even less memory
shuraj
Thank you Enigma, will you be running the store again.
Will use guys be bringing the premier line back , it use to come in 100 metre rolls.
It was teh best line to use for hook links.
Yes unfortunately after he bought Pieter an dI out it all went south.
We're just sorting out the legalities so we can take the shop without risk of future issues.
The Primer line was a top hook line but as indicated we've been testing the Bass Pro Clear 0.22 and 0.20mm and it is stronger and less memory than the Primer had. It should be arriving in 2-3 weeks
shuraj
will the line be available from all the stores that you listed below.
Will they be in 600m rolls ,.
The line is available to any shop wanting to buy them, I can unfortunately not dictate to the shop as to what they must stock.
The lines are a bass spinning line and will be only available in 150m spools and is already a well established Hook line in NEM, Mpu and GN just getting the new stock is the current challenge with the Alpha warehouse now being incorporated into the Colmic warehouse during the Eu winter (our summer)
fourie
Ek het vandag AWA-SHIMA se ION Power Specimen lyn gekoop..... 0.30 mm en 11.950 kgs  @ R60 per 500m tol
Gebruik iemand hier dit?
Enige terugvoer oor die lyn?
Ek het reeds lyn op die magnum katrolle gesit en wil dam toe gaan. Wil die nuwe katrolle en lyn gaan toets. :fishn
Ek het by Leons in Paul Kruger straat gekoop maar hule voorraad is baie laag en ek moes soek om te kry wat ek wou he.
Ek wil ook nog lyn op my baitrunners sit. Maar dit sal moet wag tot die naweek.
PI
Ek het gisteraand my longbows gespool met die Ion Power Supa Cast .16mm lyn, en is vrek angstig om by die dam te kom om dit te toets....
LeonK
PI ek het dit ook op n paar van my spoele. baie nice lyn maar jy het steeds n leader nodig.
fourie daai is verspot goedkoop aangesien ek gister gesien het vir R105 per tol by WA.
fourie
My swaer het die .25 mm 8.5 kg lyn op sy baitrunners. Ook die specimen lyn soos ek bo genoem het.
Hy sit nou by Roodekopjes en kerm vreeslik. Hy se die lyn breek elke keer as hy vaskap. Hy is ook van nature nie 'n ou wat die vis kap tot hy langlippe het nie.
Dit breek blykbaar by die voorste ogie.
Dit is sekerlik nie veronderstel om te so te wees nie.
Ek ry more soontoe en sal dan eers kan sien wat daar aangaan. Ek hoop regtig nie daar is fout met sy lyn nie....
LeonK
kyk of daar nie n snytjie in die ogie is nie.
ek het al ook gevind dat daar slegte batches lyn voorkom, so ek hoop nie dis die geval hier nie.
fourie
Rampokker....dis splinternuwe stokke. Gister die eerste keer gebruik.
Ons het gekyk by die ogies...geen merke of snytjies nie.
Dalk is hy net ongelukkig....
Myne darenteen het reg gewerk. Geen probleme nie.
9/11 on
Het nou wel nie vis met die nuwe lyn kon vang nie. Die ou lyn het al die werk gedoen. Was nie in die bui om die baitrunners se lyn te vervang nie.
9/11 off
