You all know the story , u buy some good quality saltwater lures and u need to replace the trebles, problem when attaching single hooks theres an issue with split rings /the angle they sit at and so on so i thought about this and came up with this idea: take a piece of carbon coated steel about 25-30 cm long (use the breaking strain u think will work the best + thinner steel is easier to work with) ... make a flemish knot thru the eye of the hooh , now u have to tag ends , place a crimp over the tag end and run up to the eye of the hook DONT CRIMP YET , ... pass the tag ends thru the loop of the lure ( where the split ring and treble were )........and feed into the crimp ( you will have to experiment with crimp sizes here as ther are now 4 pieces of steel in the crimp )..... with a bit of patience and pliers you can now pull the whole lot up tight only the crimp is between the lure and eye of hook NOW YOU CAN CRIMP ..... end result is a neat 1 hook setup that the gape either faces up or down depending how u want it and also hook does'nt flap around when u cast and get stuck on the lure body etc... i will try to post some pics later in the weekend , need to get some mor steel and crimps . Mike .
