Maybe have a look at the way I've set it up. works perfectly for me. The 1.5 kg anchor I bought from Sea Port. (Hulle was so gaaf, hulle het dit sommer by my huis afgelewer). The H-frame was made with 40 mm pvc piping welded together with t-pieces. One T-piece has an inspection hole. that is to drain any water that leaks in. The H-frame acts as a float as wall as a holder for my anchor rope. When I want to anchor, I just roll off enough rope to let the anchor out plus a few meters extra for movement and loop it through the one corner to prevent it from rolling off further. It is a nuisance to unroll and re-roll 60 meters of rope every time. the end of the rope is attached to a 2 meter piece of bungee cord to absorb any pull of a big swell. the caraber clip I clip anywhere on the rope that surrounds my yak. I used to use a 0.75 kg anchor, but found that heavy current (as in Langebaan) or strong wing (as in Cape south easter) tends to let me drift sometimes. I hope this might help.
PS. it is not all my own ideas, stolen with the eyes and adapted for my needs
