Aluminium L-Frame
Mangi
Right Boys, Final Product,
Frame with 25L Big Jim Box:
Mangi
Here is my cutting list for the aluminium.
Lenghts x 2: 562mm (+ 2 x corner blocks of 29mm each bring full lenght to 620mm)
Width x 3: 352 (+ 2 corner blocks of 29mm each brings full width to 410mm)
For the foot piece I suggest you get a box first and make accordingly.
Mine is 2 x 220mm lenghts.
Corner blocks/ Connect-Its used:
4 x 2-way connecters
2 x 3-way connecters (90degree angles)
If I could redo the frame, I would make it a bit more narrow.  My box does not fit on perfectly, but that is not a train smash.  Nothing that a piece of flatbar can't fix.
For you okes wanting to make your own, BUY YOUR BOX FIRST! I was dumb enough to do that last. :fbash
Daz
Had the same problem with mine, i just used a piece of angle alu to make a bar across the opening.
Mangi
Wish I could help Jannie, I grabbed mine out of my dad's garage (with his permission).
Any textile supplier should have something that you can use as shoulder straps.
Mangi
Guys, forget to add in the crossbeams that I put in my frame to strenghten it.
Basically I used the same 25mm square tubing cut to 360mm and two pieces of aluminium flatbar cut to 410mm. I rivetted the flatbar to the square tubing to leave exactly 25mm open on each side. Slid that on and bolted it to the frame.
I made two of these, one at the bottom where I attached my hip belt and one a little higher up that it fits into the small of my back.
Daz
Jannie wrote:
Mine is almost finished. I just need to know where I can get the straps??
I live in Centurion.
Jannie, i got all my straps at Army Stores in Pta West, its the only place that could help me with straps.
AnglerX
Hi Jannie
I bought mine from The Golf Pro Shop. I bought a set of replacement golf bag double straps. I paid about R 100.00 a year ago and they are well padded and sturdy. Feels like I am carring my golf bag. Just an option. There is a Golfers World in Centurion or try Pro Shop in  MenlynRetail park.
rajmank
Thanx a lot guys for sharing your ideas...heres my attemt at making the l frame..
the frame with tackle bag(empty) weighs in at 6.2 kg...
rajmank
with cooler box
still trying to find those maglite clamps
Psy
Mmmmm looks cool, but I wudnt want to cart that to Robberg!! Specially if its fulla big baits (bonnies and chokkas and all and all!!)
We were carrying about 20/22kgs - thats klomp!! Te veel!!
:fbash
rajmank
i loaded the cooler box with sinkers....weighed in at 15kg....im quite comfortable
with that weight...dont think ill be going any heavier..
i just read that report on Robberg Point...amazing stuff...here on the kzn north coast the furthest ive trekked is 500 to 700m...
