Hi Ocean,
Drop Shotting for Grunter
Tecnically my method is not drop shot but artificial lure as I do not make use of a jig head. I use a bass method called finess fishing.
2-3m long flouro leader 4-6lb. Put your shrimp which must be small on a small hook, size 12-8 light gauge and some times it could be a long shank (trout hooks work well) depending on the lure and be sure you have buried the eye and knot in the lure. Best colours are off white to shrimp, but dark green with chartruese tail also works on occasion. You can also use small worms, grubs, creature baits (if you can get, berkly use to have a super one) and tiny glass minnows or even tiny crazy charlie flies.
1 meter up the leader you can use a small split shot or I prefer a tiny mojo sinker, held with 2 mojo rubber stops 1/32 (less than a gram) or even 1/64 (less than 1/2 a gram). You can get this at any bass shop.
Best is to use a 2-4lb braid to be able to cast this light weight on a rod rated Ultra light to Medium Light (I use an ultra fast 6ft Medium Light Rod with 2 lb braid for this)
Best time are on a tide halfway out, or best as it is coming in especially when it is coming in late afternoon to twilight and you fish even into the dark early evening.
Summer/Autumn is best
Now it flats style fishing and you must stand on the bank, and do not move you feet and eventually the grunter will start feeding around you. Do not move your feet you will have to be a contortionist to make these cast as you must twist your upper body without moving your feet ever. If you move your feet they will stay away to far for you to make the cast. Water will be from 500mm to ankle deep.
I have seen grunter swimming on theri side to feed the water they are feeding in is so shallow.
Watch the fish around you as they cme and feed closley, time his spped and track his direction. Single 2 or 3 out. Then make the cast 1-3m in front of the fish, wait for the line to sink and settle. Then slowly twitch into his path, hopefully it Wala and you are in , or retreive back slowley and quietly to make the next calculated cast, without ever moving your feet.
My best is 9 grunter in a 2.5hr period, nothing huge but all nice fish.
It takes skill, patience and persistance. You need master it and practise.
Send me the pics
