2014/2015 KOB SEASON
Jacquesdw
Well done to FB guys! Prodding bottom!
My entries.....
Little sizer in Struisbaai surf on spoon
Fanie Crause
my eerste vir die seisoen in falsebaai sy het 104 cm gemeet en het my ordentelik gerev op die grinder,moet se dit is darrem lekker om een op die braid te vang.snaakse ding is die vis het verby 3 leewendige harders geswem om n pillie aas te eet.nog erger is dat my hoek nie losgekom het van my sinker nie en die vraatsige girl het sinker en hoek gesluk.dis nou lucky
BigBen
My entries.....
Congrats..What a beautiful pic and healthy speciment.
That's my goal 4 Summer...a cob on spoon....
Damn mooi foto
If you don't mind a little more info on spoon used and conditions you fished for her.
NRJP
Great catch. Is that a Shimano Nexave grinder. Just wondering. What rod you pairing it with.
Jacquesdw
Kenty wrote:
Kenty wrote:
My entries.....
_seal1_...VERY VERY NEAT!!!!...Spoon please????
:cool:..Also , if you dont mind , was she hooked on the outside of the mouth OR on the inside???...Top OR bottom...Many thanks
Hi I used the same spoon in the middle for that one just with pearl crystal flash. That and the 2 bigger spoons are all the same shape and 72g and 80g respectively. Not sure of their names, they were privately made.
Also had success on the Kingfisher V back 60g and Iron Candy SV#3, 72g especially pink. Blinged up some spoons with Fluoro Green lure paint. I like use a teaser on my hook as the profile is much bigger but not all spoons handle it.
Caught the cob late morning, clear skies, clean water but was casting to puffing sand close to shore. Hooked solidly in the top of mouth.
Kenty
Jacquesdw wrote:
Kenty wrote:
Kenty wrote:
My entries.....
_seal1_..VERY nice info ...indeed....that middle chrome one is KF 2S....the one next to that lime green looks like a Ashly Read B flat....two very good kob spoons....Well done once again!!
Toobster
Jacquesdw wrote:
Kenty wrote:
Kenty wrote:
My entries.....
@ Jacques - Do you get a better strike rate with the added flash/tails on your spoons?? I use the same type spoons in the surf, but not much luck yet.
Fanie Crause
thanks NRJP
it is not really a spinning outfit its more a galjoen setup. the real is a shimano aerlex 8000 with 50pnd braid on a shimano beast master medium 14ft rod that is made for multiplier but I use a inverted cast if you could call it that.(bottom hand releases the line on the cast)
NRJP
Fanie Crause wrote:
thanks NRJP
Thanks for reply. I have a shimano nexave 6000 paired with 12ft finnor. Hope it will be able to handle a kob that size
NRJP
Fanie Crause wrote:
thanks NRJP
Fanie Crause
NRJP wrote:
Fanie Crause wrote:
thanks NRJP
I am not expert but that sounds good guys use much lighter setups and catch bigger fish then this. what line /braide do you have on I think anything from 20 to 50 pnd should be fine,im not a expert tho,so gooi en kyk
BigBen
Couple of beautiful fishing evenings ahead for False Bay with the baro climbing slowly but steadily towards that sweet 1016
Bevid
Some mooi fish guys. Well done. Glad to see the cob are coming out in other places. It's pretty bad here at the moment. Got a session planned for the weekend. Here's hoping.
BigBen
Welcome back stranger
Bevid
Eish Benna dinge was maar rof bro. Werk was mal besig en die exsamens is nou verby. Die laaitie kannie meer wag om by die see uit te kom nie.
