FeedingFrenzy
Yes you read correctly! Here in Cape Town we have people that are permitted by Provincial conservation authorities to trap and export platties for medical research. I don't know if they still do it though with all this amphibian fungus that's annihilating rare amphibians and is supposed to originate from platties - worth thinking about - don't release platties anywhere!!!!
OK the trap! Make a rectangular box frame out of pvc tube or any similar rigid plastic tube - either use pvc weld to fix together or irrigation elbows and T's. It will look similar to the trap shown in the original plattie trap thread - the only major difference is to use chicken wire to cover it and make the funnel with. It takes a while to rust badly but is relatively inexpensive enough to re-cover. Don't make the trap too big - there's no need to - rather make a few smaller traps.
Remember to make a flap or door that can be opened. Also make the funnel entrance (the narrow end of the funnel) about the size of a coffee mug. Make two funnels per cage trap - more platties can enter at once. OK bait the thing up with bones - that's right, get some large meaty bones from the butcher and tie wire around it and hang it inside the trap.
Very important - if the trap is going to be left for longer that half an hour to an hour then the top of the trap must be above the water - so that a gap is left for them to reach the surface and breathe!!!!! Otherwise you haul out a trap full of vrot platties that drowned days ago!
The reason for the chicken wire is that when you haul the trap in the water drains instantly and the trap is light and easy to remove. The reason for the bigger funnel is that small carp and kurper etc are also attracted to the bones and so you will get a couple of small fish baits at the same time.
Oh and don't forget to tie a rope to your trap and tie it to a peg or tree on the bank!
