Wiring Chart
Racer-X
Hi
I found this color code chart on this website: Link
I'm not sure how accurate it is.
I was struggling to wire up my 703 control box.
This helped.
Yamaha Outboard Wiring This information was provided by secondary sources but is believed to be accurate.
Code:
BLACK         = Ground
Code:
RED           = Battery Positive; SW3 Oil warning red light V4
Code:
YELLOW        = Ignition ON 12-volts; Four-stroke lighting coil
Code:
BLUE          = Instrument lights; choke; choke circuit;
Code:
                Ground potential oil transfer; High speed Charge Coil
Code:
GREEN         = Tachometer signal; lighting coil lead; knock sensor
Code:
ORANGE        = Trim position sensor
Code:
PINK          = Oil and overheat signal ground
Code:
WHITE         = Ignition stop circuit; SW1 oil transfer off position V4
Code:
BROWN         = Starter circuit; Low speed charge coil; Positive "+" potential
Code:
                to oil transfer pump; SW2 transfer on position V4
Code:
GRAY          = Warning circuit lead; Over-rev. control; Four-stroke tachometer
Code:
SKY BLUE      = Trim up
Code:
LIGHT GREEN   = Trim down
Code:
YELLOW/Red    = Diagnostic lead from ECU
Code:
PURPLE        = ECU groud to enrichment solenoid V76
Code:
BLACK/Yellow  = Thermo sensor
Code:
BLACK/Red     = Remote oil tank ground return, PBS to tachometer,
Code:
Code:
BLACK/White   = Ignition coil primary lead
Code:
GREEN/Blue    = Crank position sensor
Code:
GREEN/Red     = Red oil warning light ground through SW3 in main tank oil
Code:
                sensor to tachometer
Code:
GREEN/White   = Crank position sender; Lighting coil lead to rectifier
Code:
BLUE/Green    = Main tank oil level sensor SW2 oil transfer circuit
Code:
BLUE/Red      = Main tank oil level sensor SW3. No oil warning circuit
Code:
BLUE/White    = Main tank oil level sensor SW1; Oil transfer OFF circuit
Code:
BLUE/Yellow   = Shift cut switch
Code:
PURPLE/Red    = OX66 #1 injector
Code:
PURPLE/Black  = OX66 #2 injector
Code:
PURPLE/Yellow = OX66 #3 injector
Code:
PURPLE/Green  = OX66 #4 injector
Code:
PURPLE/Blue   = OX66 #5 injector
Code:
PURPLE/White  = OX66 #6 injector
Code:
RED/Yellow    = Key on power through fuel relay pump; power to ECU;
Code:
                Fuel pump and fuel injectors
Code:
WHITE/Red     = #1 pulser V6
Code:
WHITE/Black   = #2 pulser V6
Code:
WHITE/Yellow  = #3 pulser V6
Code:
WHITE/Green   = #4 pulser V6
Code:
WHITE/Blue    = #5 pulser V6
Code:
WHITE/Brown   = #6 pulser V6
Code:
YELLOW/White  = Electric fuel pump for electric carb system (ECS)
