Hey Angler,
My 2c.
For the clip part, 1.6mm stainless steel tig wire from afrox, I think it was like R149 a kg.
For the grapnel wire, use spring steel wire 1.6 mm for smaller sinkers, and 2mm for heavier ones - Not tig wire
I cast 8 ounce sikers, and open the mould within 15 sec, and the lead has set by then. Just ensure that the lead is HOT HOT HOT before pouring. I also heat the mould on the side of the cadac while the lead is melting before casting the 1st sinker. Helps to keep the lead molten when pouring so it doesnt set and you have half a sinker.
