wire for sinkers
BigT
Hi there guys
Just wanted to get some advice on the steel wire used in the making of wire sinkers. Recently decided to modify an old bottle mold to accommodate the wire. Starting to take shape and now all i need is wire. Tried using stainless welding rod but not working.
any help appreciated:welcomesea:
Kumz
Big T do u have pics ...
I wud like to see what u did ?
What welding rid did u use , i wud the that Tig welding rods shud be fine ???
Ta
Patrick
There is a marine grade S/steel wire that the industry sell. i think its called p3 or t3, something like that. Where are you situated? may have a number for you.
BigT
Hi KUMZ
This is what i have at the moment. The wire i'm using is stailess steel braising rod. it works but just not enough spring in it. thats why im looking for a diferent type of wire.
BigT
Still workin on how to accommodate the bait clip. nothing a bit of filing wont solve though.
BigT
Hope the pics help. anything to save a couple a cents and get my bakkie to the beach more often.
Raggieman
instead of putting bait clip on the sinker why not use breakaway bait clips - I found they work better than the bait clips on sinkers
Hey Reefs what you say ?
You're right Raggieman.
IMP2 CLIP....:spite... she's a beautiful thing! But expensive though - if costs cutting is the priority, then IMP2's are not the way to go. If ease of fishing is, then they are magic!
Pylstert
BigT, there is no groove on a bottle sinker for the wires to clip into, strongly doubt that you are going to get those wires to stay in place. For a bait clip though, you can make that out of stainless steel wire, I have seen people make them, if I get a chance will draw a pic.
dup-zn
Hi Big T
You need to get 1.6mm spring steel.
There is nothing better than that.
Other wise you could use 1.6mm (308) stainless steel tig rod.
The problem with the tig rod is that it does not have any spring in it.
You also need to put the grooves in the sinker itself.
So in the moulds there should be bumps. You should be able to make those bumps with pratley putty.
The tig rods you can get from any welding shop. They are about R130 per kg.
The spring steel I'm selling at R75 for 200 wires cut to the right length.
I also make grapnel moulds from a 3oz to 10oz
You can use the same moulds I'm making to make your own nylon grapnels.
BigT
Hi there guys
Thanks for all your input. Greatly appreciated. As for the wire im using stainless braising rods. But, as i said too soft. The little grooves for the wire took me a minute to make manually. although the pratley steel is a great idea thanks dup-zn.
By the way been back to the drawing board or should i say the garage and my trusty old bottle mould now makes wire sinkers with a bait clip.  To be used with or without the spring wires.
Any further info greatly appreciated.
I knew bringing this idea to sealine was a good idea.:welcomesea:
Patrick
Hey Big T,
Give Steven at Workmatch a call - 021 9397943. They're in Plattekloof and they sell smaller amounts than most other places. Ask him about the marine grade S/steel.
Simen
Big T. I use to make my sinkers exactly the way you are before getting a mould from Dup.On your last picture you now have to use a triangle file and make a shallow notch into which the wire can bed it self. This notch will prevent the legs from folding over without tention ( line tention ) on them. The deeper the notch the harder for the legs to fold backwards.
BigT
Hi guys just wanted everyone to know that i fianlly got a the wire for my sinkers.
Eventually got  the  wire  from a  local  tackle  shop at 30c each. Sorry guys the owner wanted to remain anonamous.
So total cost of my sinker:
Wire 2 x 30c = 60c
Lead (1kg which makes about six 5 ounce sinkers) at R14 i.e. R2.33 per sinker
TOTAL COST of sinker : R 2,93
Sorry one thing i didnt include was the gas to melt the lead but thats easliy solved by using the fire the next time i braai. Kill two birds with one stone.LOL.
So now the million dollor question. So why are we paying +/- R 10.00 a sinker?
Thanks sealine for all your support in my little project. :welcomesea:
BigT
Hi there Marthin
For a sealine supporter I'll make them for free. LOL
With the money i'm saving on making them myself i can afford to share.
