Winter advice for a dam I've fished before in the summer
axle
Hi guys
Need some advice as to an approach to the dam I'm targeting this weekend. I'm a specimen carp angler but do enjoy chasing a few bass too. The venue I'm going to this weekend I have been to before - it is close to Groblersdal. It's a small dam of about 2-3ha. Previously I caught many bass there in the shallower water (1.5m and less) on a soft plastic frog lure. This was however in the height of summer (Dec/Jan). Can you give a bass angling novice some tips as to where to target them and what will work? Should I try the frog lures again even though it's winter and there are no frogs around?
Thanks in advance
VaalieBassman
Bass tend to be much closer to structure during the winter and a slower approach is needed. Lures with less action works better!
Try a senko fished very slow (slow as in let it sit for a minute before twitching it and hardly moving it from where is was).
Drop shot with a small bait like a cut tail will also work as long as your presentation is correct and as close to structure (sometimes inside the structure) as can be!
Tight lines!
axle
Here the results. Nothing big but a lot of fun. All caught on plastic curly tail and minnow 1.5m from the bank amongst the rocks.
