windknots
roland
got myself 2x windknots on the fireline this morning. lost about 15m , not happy. havent had this problem with the viper braid. can the experts please explain why?
wp34
Maybe your reel has too much line on?? Overfilling is a common cause for windknots. I had the opposite happening to me. No windknots with Fireline and plenty with the other brands.
Brian
roland
Brian
nope, the reel is just past half :(
to be honest, i hate fireline. got the same this morning, around a rods eye. lost my fave spoon cos of this. keep an eye at the classifieds section lol
200ts
Hi guys, if you do not mind my asking what causes a wind knot? I tried braid for the first time this december and it worked brilliantly for me. I was using my g3 with standard eyes ( upgrading the eyes soon ) anyways the first day it was brilliant. then the next day for no reason i would cast my sinker off , time and time again, eventually went back to the machine reels. I do want to get this right though. in my case it could be the eyes that where too small.
Richard Ohagan
Check the way your reel packs the line on the spool, some reels pack the line on in a cone form, small at the bottom to big at the top, when you cast with the line packed it pulls clumps of line off the top of the reel and this is what people call wind knots. To remidy this, some reels come with spacers that you put in under the spool, add some in or take some out till the reel packs straight or slightly bigger at the bottom, this should help with the problem. Another reason is because the line becomes loose when spinning, every now and then hold the line under tention with your fingers and wind the line on tight again.Hope this helps.
roland
thanks richard. i'll try the tension part cos it winds up evenly
fishersteve1972
I had this problem once or twice until I got into the habit of , when turning over the bail arm I check to see it the braid is actually on the spool and then give a quick tug.
I did find previously to this that sometimes the braid tends to stick on the top drag and when I start reeling it just forms a cone of braid on the top of the spool which causes the knot.
So give it a tug.2c
