Windknots - Eish
DWB
Just loaded my slade 2500 with 10lb power pro braid and took it to a dam quickly to go check some lure action, i used my daiwa exceller 8'6 and first casted a gladiator onda onda type lure twice then put on a zara spook jr, first cast great, second cast windknot around a guide, braid off lure flying.
Now is suspect it might have to do with the fact that you constantly twitch the spook or that the reel is quite old....
WHAT TO DO?
I am leaving for Qatar in 2 days and need to be sorted.
Any advice on another reel for say R500 that would handle it better...
Urgent advice please
Warwick
Could be line lay my some reels just don't do it well, or good old leader knot? but as Mombak said overfilling is #1 Cause.
I have also found that my casting action influences it somehow, I could be dreaming on this one though.
Nepptune
Or smoking your socks??? :fbash
Deon - I have found with light gear used for fishing plastics ( I hate the term dropshot ) one needs to take a long cast every 8 to 10 casts and then reel in fast and even with no twitches to get the line laid down nicely again...
Like you mentioned, the "twitch-twitch" action ( as used when fishing plastics  slowly ) defintely can cause issues with lines lay of braid on spinners, and especially with your ultralight braids like 10lb and lower, it doesn't take much to cause a wind knot and resultant bust off and donation of your lure to the water you are fishing...
Could also be the leader knot as Sock smoker above mentioned, or your casting action...
And as already stated above, line lay would most likely be your number one cause of wind knots...
Dingleberry
I have found that by far the biggest issue is having to long a leader. It seems to work better if the leader knot is forward of the tip eye before casting - ie the knot doesn't travel through the guides.
The Moose
There are a few things that cause wind knots,this may help to prevent them in the future:
Make sure that the braid is spooled on quite tight.
Do not over fill the spool.
When retrieving, even if it is an erratic motion, lift the rod before reeling in to keep tension on the line.
Make sure the reel is smooth and the spool is not jerky.
Make a distance cast with a fast retrieve every now and then(like what Nepptune mentioned)
DWB
Sorry guys, should've mentioned there was no leader involved, i used straight braid. Just wanted to go check how a lure swims and then quickly casted a zara spook, so i guess the action of the spook where you have to give it some slack line probably screwed it up. I serviced the reel and made sure the roller works etc so we will see, otherwise i will be buying a new reel today
trier
most probably the reel is overfilled and i find the casting type reel (ie longer spool ala saltiga surf) does not give me these knots. also every 10 or so casts i reel in whilst pinching the line to force the twist out of the line/braid
blaasoppie#1
x2 on the overfilling - Power pro 10lb is relatively stiff (12, 15 and 20 lb too) when it is new and throws larger coils off the spool which hook up on your back guide. It will take at least a full spinning session to settle on your spool and you will normally have to throw off at least 20m from full spool condition before the line stops with all that nonsense.
I have spooled my new Stella 4000FD with 10lb Jerry Brown solid which is nice and limp and i have not had any wind knots so far even with a full spool.
Start off with a cheap lure.
DWB
Gee thanks...LOL
Nightfox
I have used a couple brands of braid and experienced windknots on all of them in certain conditions with certain retrieves and consequently had to pinch the line every 8-10 casts to get the line on with tension. Got a spool of stren casting braid and never had a windknot problem whatsoever.
neilg
Got a solid bunch up today on 14lb Fireline !
Lekka by die see
DWB
Yes yes, i\m in Qatar right now and have thrown away more Power Pro than i Like to. Even straight after you wind it up under tension, the next cast bam, windknot.....
DWB
Hehe, switched from my Exceller to my berkley and have not yet had a knot, but the Stradic 4000 is in the mail....
Thinking the small guides on the exceller is playing a roll
neilg
Thats good news !
Rip those sh#tty guifes off the Exceller and relace then with Fuji ones, go big
My 9ft Air will be finished tomorrow, new guides, cant wait
foot soldier
i had windknots using 20pound powerpro,,,switched to 30pound,,,not as many,,,threw my fin nor in the shed & replaced it with a diawa seagate3500h & 20pound powerpro,,,,problem solved
