Anyone tried a wind-on made with 49 strand 275lb or 200lb carbon coated?
Steel wind-ons used deep sea - reckon it will be correct thing to use for swim baits - the dacron connected to the trace and the trace is the full 9m length.
If using a 1.8mm wind-on leader and want to attach a piece of 150 or 200lb wire to end of leader (for a slide bait) without tying a massive figure of 8 (on to a swivel) or albright - how are you attaching?
I have considered to put another piece of dacron at the end of the mono to connect the mono to the wire - anyone tried this? This can be done 2 ways - by letting the dacron "clamp" on the mono and the wire. Second way is to have a loop on the dacron (same as other end) and then to connect this to a power swivel on the piece of wire. (slide stopper ring on one side and another power swivel on other end - with the steel in between)
The thought has come to mind to leave the piece of steel off all together when sliding if using such a thick leader.
Any comments or idea?
