Wind-On (Steel)
misguide
Anyone tried a wind-on made with 49 strand 275lb or 200lb carbon coated?
Steel wind-ons used deep sea - reckon it will be correct thing to use for swim baits - the dacron connected to the trace and the trace is the full 9m length.
If using a 1.8mm wind-on leader and want to attach a piece of 150 or 200lb wire to end of leader (for a slide bait) without tying a massive figure of 8 (on to a swivel) or albright - how are you attaching?
I have considered to put another piece of dacron at the end of the mono to connect the mono to the wire - anyone tried this? This can be done 2 ways - by letting the dacron "clamp" on the mono and the wire. Second way is to have a loop on the dacron (same as other end) and then to connect this to a power swivel on the piece of wire. (slide stopper ring on one side and another power swivel on other end - with the steel in between)
The thought has come to mind to leave the piece of steel off all together when sliding if using such a thick leader.
Any comments or idea?
tuna
Yes, i have a few of them, i use them especially down in the transkei
You use the normal 200lb dacron onto about 6m of industrial cable(work out way cheeper than the normal cable)
Im talking about 440lb steel , not 200lb carbon coated ,you wont get the dacron to grip on 200lb carbon coated
misguide
the 440lb steel should be the same as the 49 strand 400lb wire from K/Fisher.
i am going to make a few swim bait traces with the entire trace (400lb 49 strand) of 8-9m being connected to the dacron loop. that way there are no joins etc for max strength!
how are you attaching the piece of wire on the end of your mono (wind-on leader) for slides? that is for the thicker leaders such as 1.6mm - 1.9mm.
if you use a swivel on the wire piece then you will have to join with a figure 8 as the albright will be too big (thick). even the figure 8 here concerns me as the knot becomes so big for the slide to go over!
tuna
the end of the wire goes into a 200lb windon dacron
The the loop of the dacron goes throught the loop on your mainline(catspaw)
Bel my as jy nie mooi verst nie nul sewe 2 03555 nul twee 5
400lb strand werk goed maar soos ek se dit werk net ongelooflik duur uit, industrial kabel kos iets soos R1.50 n meter
