Will This Work
Hi Guys can anybody help to tell me if this will work , adding extra weights
for futher casting distance ^^..
TotalNoob
Will work for distance, but will severly impair the lures swimming action,That lure will drag on the seabed.
You need those triangle hook weights - goodluck finding them!
Stapies
Mnr die haai van Mosselbaai...
Ek stel voor jyu gaan na 'n viswinkel en koop die drie angel hoeke met die lood op hulle stele. Dit is meer as genoeg gewig om ver te gooi en belemmer nie die aksie van jou harde lure nie...
Dai tegniek word ook in die transkei gebruik om kabeljoue en elwe van die rotse af te vang in die see en werk wonderlik...
Jacquesdw
It might work with only one weight. Last month (or before) a local bass magazine- forget which one- had an article on deep-hacking which is basically a deep diving crankbait with a worm weight sitting on the line and against the lip. The Japanese figured it out to get bass really deep down. But it would mess up your casting. You want the weight at the tail of the lure so that it flies well like a arrow or spear.
neilg
Only add a weighted triangle to the middle, not the back
Not perfect for casting but gives great aggresive action to lipped lures
Other solution - buy clone lures - heavier and made for casting
Mouldz
No.impares the action ,in Transkie we used to put bigger hooks and then flatten a sinker and cut thin strips,wrap these strips around the hook shank
iggy
Easy solution.Cut the ball lead halway to the centre, then use it like a "split shot " and clamp it onto both treble shanks. Will keep the balance and not effect the action.
