Will Drop shots work in Durban Bay??
Faizal-D
Hi,
Will Drop shots work in Durban Bay?? Has anyone ever caught on drop shots? What drop shots were used etc?
:wfish
The Boss
I need info on this one as well please ! SERIOUSLY.
I also tried dropshotting in the harbour, but to no avail. Although it was very late we were at a spot right inside where the guys were catching Grunters very late at night. I didn't even get a nibble or anything....or maybe i used the wrong stuff....hey I dunno.
So if someone can help it will be gr8ly appreciated!!
buxj
DROPSHOT DOES WORK in the durban harbour.
a friend and I who started using this method of fishing together in Jan has had success in the bay. There are many factors to consider which can determine the outcome of dropshot.
1. tackle
2. location
3. tide/weather
We also had no results for a while and did some research, asked the pros and changed things. You got to have correct outfit for that method of fishing and the fish will come! It also takes alot of practice!
what type of tackle are you guys using?
We use loomis dropshot rods. I now use a shimano baitcaster while my friend uses the diawa regal. I use braid and he uses mono and we still get results, infact he has had more fish on then me. We fish of the banks, channels, coaling alliance, silt canal. Fish on dif columns on dif days and its really fun! BUT very tiring!
JB
The Boss
I use a shimano 2000 coffee grinder(very small reel) loaded with Berkley fire line +- 14 pounds , and then use very light drop-shot sinkers. It's the plastics that i battle with. I just about tried everything from big worms to small Jerk shads a.d nothing happened.
:fbash
Thanx for the input
buxj
what rod do you use?
the most important thing from your tackle is your rod because it creates the action.  fast action rods work great. they range from around R300 upwards for a good graphite rod. tell the sales guy it for dropshot!
I like your choice of line! fireline is bloody tough! u can reel out a monster with         14 pound FL BUT its abit heavy to begin with. FL is 1 of the thickest, i would put on 8 pound braid (kingfisher braid) to get the feel of it before i go with bigger expensive line The carbon leader DOES make a diff, use it. braid is very visible especially when if fades.
your reel is fine for now, fish will bite a lure if you using a R3000 shimmy or a R300 diawa.
Lures
i personally use gulp alive 4" minnow (emerald shiners), i fish in the afernoon going into the night so use darker colours at night (somehow that work!)  BUT my mate uses Mc A products 4" minnows they also work.  We initially started using small minnows but they never worked. i think 4" creates the best action + i think
big lure = big fish ::S
If you wanna get knocks or a nice pull, do the following. (solunar/ wind depending)
go to silt canal on going out water and cast near/under the bouys. let your line sink then start reeling in and give some action every 3 rotations. gentle action. You are bound to hook something. I lost a huge fish 3 weeks ago, it took, ran and ended up snapping my braid (suffix 8 pound). I promise i could bearly hold my rod, almost fell off my boat,lol.  :fswim
good luck!
JB
The Boss
Thanx for your input
Boat you say? Maybe we could go together some time. One is never to old to learn. With Bass fishing in and around the PTA/Witbank area I knew exactly what to do when and where. But this is very new to me and hopefully I can crack it with an experienced "drop-shotter"
salty
i have caught many fish on dropshot in the harbour, kingfish, flathead,queenfish,pickhandle barracuda,torpedo scad etc
it does work jus try harder
buxj
wow!
please share some info
1.location
2.tides,wind,moon
3.tackle
4.lures
seem like you perfected it! how long have you been doing it?
your fav retrieval style that you always get a hook up with spec lure?
thanks mate!
The Boss
BUXJ
you can phone me as well sometime. It'll be gr8 to hook up and do some fishing together.
Tel no 0823178147/0824528091   FRANCOIS
Tx bru
salty
sorry for the late reply.
in dbn harbour the white lures work well for me. 3" to 5" slim lures.
spring tides always better. look for a rip in the water near channels or structure. just before dark is seriously the best time in the harbour.
with retrieval it depends what you targeting. you dont need anything heavier than 6lb fireline and 20lb leader.
