Why Do we Fish?
ronny
Why do we Fish
Why do we fish? It's exciting, it gets our minds off life's problems, it stimulates our brain as we think of ways to outwit the next fish, it keeps us physically active, it allows us to socialize with those of a like mind, it lifts our spirits, it energizes us, it gives us satisfaction and it satisfies our primal urges. Do these reasons sound like other sports that give an individual a sense of contentment? I think so. So why don't we just admit it, fishing is a sport. Is it not time that we start treating it like one? If we are ready to concede that what we do is a sport, then how can we start changing our own fishing activities into a true sport? What follows are some thought provoking ideas on how we can accomplish the transition from harvesters to true sportsmen and women. The KZNCAU clearly endorses this message as seen in the notice to clubs prior to the Annual Meet Competition.
IMPORTANT NOTICE
CONSERVATION –Once again we will be in the public eye on this weekend and must absolutely minimise the unnecessary killing of fish.
[align=left]With this in mind we remind members of Competition Rule 36 [a[ which reads:-        .[/align]
          [/b]“All fish caught at Annual Meets shall be measured on the beach and, unless retained for personal consumption, be returned immediately alive to the water provided that the measurement of any such fish shall be certified in writing by any participating Club member.”[/b]
 [/b]
Members may have their fish witnessed by their own team members.
[align=left]In terms of the Marine Living Resources Act no angler may be possession of more than 10 fish, i.e. 2 Bronze Bream + 1 Kob + 2 Garrick or 1 Cartilaginous fish etc., provided that this limit does not apply to those species listed with no bag limit, and to those species with a bag limit exceeding 10.[/i][/align]
We urge you all to take care in handling captured fish and to get them back in the water as soon as possible.
Catch and Release
What do we really know about catch and release? Do we know how to practice it? What are we trying to accomplish by doing it? First, let's define what catch and release is trying to accomplish. It is a method of handling fish that reduces trauma and shock caused by the injury sustained by the hook being physically touched by the fisherman, oxygen deprivation, fear, removal of its protective coating and removal from its environment. One of the latter can cause a fish to bleed out and all can cause a fish to go into shock and die. So how does a proper catch and release technique lower the risk of possible death to fish? All fish that are not going to be weighed and/or photographed must be kept in the water and they should never be touched. Those fish that you wish to weigh or photograph must be kept in the water for a period of time that is long enough for them to recover from oxygen deprivation. Also, the hook should be removed in the water.
A good analogy for oxygen deprivation would be: an Olympic athlete runs the marathon and at the finish line someone chokes them. Very few of the Olympians would survive. Removing a fish from the water at the end of a fight chokes them and very few can survive this trauma. It is important not to remove its protective coating. The best method is to employ a fish cradle. It should be long enough so that the species being targeted fits entirely into the net. One end should be closed, the netting should be weighted so it sinks, the frame of the net should float and be made of a material that does not easily remove the fish's protective coating.
Handling Fish
There is definitely a right and wrong way to handle fish. First and foremost, they should be touched as little as possible. I often watch in horror as fish are grabbed behind the head at the gill plate. The reason they are held there is the thumb and middle finger will slip under the gill plate and they can be held firmly. Have someone with large hands grab you behind the head at the neck and squeeze hard. Now, relate that to a struggling fish and ask yourself, how many will be injured or killed using this technique?
The next method, commonly used, is to gill a fish. This method requires an individual to slide his fingers along the bottom of the gill plate, pull the gill plate open and then slide the fingers up inside the plate, without putting their fingers in the gill rakers, and lifting the fish from the water. The gill rakers are very delicate and can easily be damaged. You can't avoid coming in contact with them when using this method. When the fish is removed from the water the gill plate supports its entire weight. When the fish thrashes you can hear the cartilage breaking. Not many fish can survive this kind of trauma. Get someone to stand on a chair and put his four fingers under the side of your jawbone and try to lift you.
The next method commonly used is called lipping the fish. New lipping devices have been developed so this can now be accomplished on fish with teeth. Have someone stand on a chair and put their thumb inside your mouth and their fingers under your jaw and attempt to lift you off the floor. Just imagine your entire weight being suspended from your jaw. To hang a fish by its gill plate or lip puts it in a very unnatural position with no buoyancy from the water. A fish's internal organs can be damaged as the fish thrashes and even though it swims away, when released, it will later die.
Hooks
These are probably the biggest survival factor for a fish. Hooks cause more damage than any other item in your tackle box. The larger the hook, the greater the potential for serious damage. Multiple hooks are hard to remove, often hook a fish in more than one place, and seem to have an attraction for the fish's eyes. A badly injured fish will bleed out in two minutes or less. If you are into a smash, keep the fish that are bleeding badly (Edible) and release those that are not.
At the recent KZNCAU AGM the various representatives from the clubs voted not to retain the use of barbless hooks. The message that this sends does not bode well for our sport.
What can we do to reduce the carnage caused by hooks? Require that our legislators (SASAA) ban barbed hooks and treble hooks. If we want our sport to be known as a true sport then we need to demand that single barbless hooks be made mandatory. Oh, I can hear the outcry already: I'll lose too many fish. It's too hard to hook up a fish. We want things to remain the same because change is not easy to accept. If we don't change, we can look forward to further size reductions in the fish we catch, greater restrictions on catch limits, higher costs, less opportunity to fish and all resulting in fewer people using the resource.
Now some would say, "Great!"to the last statement. But security of the resource is provided in numbers. This translates into less fishermen and millions of kids deprived of a recreational activity that is second-to-none. As the responsible adults of our time, we have to make the right decision. Which one will you make?
“Limit your kill; don’t kill your limit!”
After being caught and released by an angler, fish may die for a variety of reasons. The most common causes of death are the physiological stresses caused by the struggle during capture and injuries caused by the hook or the angler. Some fish may die even though they appear unharmed and despite efforts at revival. Fish that struggle intensely for a long time during capture are usually exhausted and stressed from the accumulation of excessive amounts of lactic acid in their muscles and blood. Severe exhaustion causes physiological imbalance, muscle failure, or death. Therefore, use the proper weight-class tackle; land your catch quickly, and when possible, leave the fish in the water while you release it. Any exhausted animal needs oxygen to recover!
Hook wounds may appear minor to anglers, but damage to the gills, eyes, or internal organs can be fatal. If the fish is hooked deep in the throat or gut, research shows that it is best to cut the line at the hook and leave the hook in the fish. Prolonged attempts to remove the hook often do more harm than good. Fish are capable of rejecting, expelling, or encapsulating hooks. Encapsulation is a process whereby the fishes' healing process causes the hook to be covered with some form of calcified material; or a-cellular tissue. Steel and bronze hooks are less toxic and are rejected or “dissolved” sooner than are stainless steel and cadmium-plated or nickel-plated hooks. Here again I believe that SASSA should regulate the types of hooks that we use. Two types of hooks, barbless and circle hooks, are known to reduce injury and mortality of released fishes. Barbless hooks reduce tissue damage and handling stress because they can be removed quickly and easily. If barbless hooks are not available, simply use pliers to crimp or remove the barbs from regular hooks. After having hooked a fish, don’t give the fish any slack, because it will be more likely to escape from barbless hooks than from regular hooks.
The use of circle hooks has been researched and compared to regular hooks–often called “J” hooks–in several countries. In all of them except with flatfish, circle hooks were shown to result in significantly lower hooking mortality and higher catch rates. Overall, research shows that circle hooks improve catch rates and reduce hooking mortality which results in positive impacts on exploited fish stocks.
Gaffing
Our coastline varies from region to region, therefore a blanket ruling of “No Gaffing” will not be practical. No Gaffing should be allowed on sandy beaches and certain Rocky points in the vicinity of beaches. The angler must direct his fish to these beaches should he hookup while fishing off the rocks. There are certain points especially off the Transkei coast that warrants Gaffing. The size of the gaff hook and the placement of the hook into the fish needs to be regulated.
The purpose of this article is to inform and challenge other competitive anglers to embrace change in order for our sport to progress.
By Ronny Naicker
