whiskas cat food
jjec
the other day i was battling catching mullets when i guy walk up to me and said, why don`t you use whiskas cat food and mix it with rice..... to get them closer ...so i tri this setup....and ^%$#@ it work....
braailegend
You can also mush your old sardine with the mix, works just aswell. I always have a box of pillies lying somewhere in the fridge.
While I was onboard ships, we had Massive scools of harders by our galley's overboard discharge, they just love rice.
Ninja-Nic
You can even mixed some cheap tinned cat food with a bit of cooked oats. When you get to the water, just mix in a bit of sand - makes it easier to throw in small balls and lets you get it out further. I've caught a few pommies, lots of sandfish and many zebras this way. You can do a search here on sealine for chumming. It works.
chokka 123
when we are bored and go and fish for harders we chum sards or pike and it works well! if you want to catch them take a small no 12 and a pinch on sinker and cast and retrieve it slowly so that it sits about a meter under the surface or use a net
