Whiplash as "mainline"??
wp34
I have a 275m roll of 20 lbs Whiplash. Will it work for mainline instead of Fireline?? Is it a casting braid?? I normally use it for backing so I am not sure.
Help me out please.
Brian
jomac
the main difference between the whiplash and a product like fireline is that the fireline etc is bonded whereas whiplash is woven. All that this means is that the fireline  is more abrasion resistant so wont be damaged by continous casting and retrieving or rubbing on rocks as quickly as a woven braid would, but that said whiplash is a bit smaller diameter wise and if you are planning on spinning for garrick etc it would be ok
wp34
I had an Shimano Ultegra 10 000 and that was my backing. Sold the reel and now dont know what to use it for. Will stick it on the Cabo then.
jomac
ya im going to put 20 lb fireline on mine for spinning and get a second spool with 50lb powerpro for jigging and plugging up this end of the world
the whiplash isnt the best for casting ...i tried it and i got alot of wind knots...then i changed over to fire line and the problem was sorted...now i only use whiplash for backing and dropshot of my boat deep sea
tremosso
I put 300m of 50lb whiplash on my Stella 8000 hoping it would be fine for everything, spinning, DS and even light jigging/trolling. I guess I should have read your opinions yesterday...
aquadementia
no worries tremosso, iv got 50lb on my spheros 6000 for light jigging and its great, never had any problems. Also use that reel for surf casting, no problems there either. Its killer for trolling a deep diver cos its so darn thin.
Brian, I used 50 and 100lb Whiplash on my Stella's on a recent trip to Kilwa - Jigging and Popping. No problems whatsoever.
Mussels - All braids will eventually gooi a wind knot - if you cast enough with them. Even Fireline.
wp34
Hi guys. I took Barry Wareham's advice and filled up with Jigman braid. 260metres of 20lb Whiplash for backing and 200 metres Jigman topshot. It casts like a dream(so far!!)
Brian
jaccil
You are probably better off using it as backing on one of your medium/edible setups, but you can use it for a light spinning outfit (size 3500 or 4000 grinder).  Such a light setup is also ideal for a drift bait as you'll be able to feel the slightest touch.
I've used 20lb and 30lb Whiplash for spinning and it's great for casting light lures/plugs.  I have had windknots from time to time, but once I upgraded to a Stella (special design to prevent windknots) there were no more.  Be careful of some grinders like Okuma where braid this thin can get stuck in the roller.
Because of it's lack of abrasion resistance, it is not suitale for targeting dirty fighters over rough ground.  I tend to use rubbing leaders of less than 1m while plugging and have lost a couple of lures and fish when the fish dive behind some nasty rocks.  As long as you can keep the fish out of such areas, you'll be fine.  Unfortunately it's those areas that hold the fish I'm after here in the UK (sea bass) and that's why I now tend to use Fireline in those areas.  I still have Whiplash on my spare spool, providing the option of more line and a higher breaking strain.
jaccil
I started the reply above more than 2 hours ago but got distracted by other things...  Good luck with the new setup, it sounds right!
