Which Mono has the least memory?
Shimmy
I have been using Docks mono but have been having problems with the odd nest forming when i retrieve.
I read that Ultima has the least memory but i cant find any at the local tackle shops.
I saw some Trilene and it says low memory on the box...
before i buy it i thought to ask around 1st
Any advice will be appreciated.
Thanks in advance
Shimmy
thank you sir, i am leaving for a 6 day fishing trip tomm and
had to get something so bought a roll of the Trilene.
will check for those you suggested when i get back. enjoy the holiday....
Brakkanjan
I use XX 7 LBS as my mainline on my reels. I use the 20 LBS XX as a leader or the Awa Shima .4mm.
The same XX 20 LBS I use as a leader I use as the mainline on my traces. Hooklines I use Maxima Marine Green.
The XX that I use is the Brown Cameleon Mono. Been using it for years and I am very happy with it. Also it doesnt cost an arm and leg to replace.:raine
Zoompoep
@corsanostra
Gebruik jy n aasboot of roei jy die lyne in ?
Dan is dit geneig om dit te doen?
Daar is n paar dinge wat mens kan doen om dit bietjie minder te maak.
Shimmy
hi,
ek vis van die bank ( cast), het nie 'n aasboot of a canoe nie.
ek moet se' die trilene werk goed uit, niks probleme vandat ek dit gebruik.
Shimmy
het a nuwe roll van die Double X maar al my spools het nou die trilene op.
het 'n spaar okumu topaz katroljie met baie dik mono. sal die xx opsit en bietjie toets.
dankie vir jou voorstelling
Sidd
Been using XX for a few years now.
Would like to try out the Awa-Shima lines.... heard some good stuff about it.
Naruto
XX Platinum Plus.
Awa-Shima Supercast or True Cast and Specimen lines.
And from what I heard the Berkley lines are very good.
Shimmy
The Trilene is a Berkley Line.
at one tackle shop they had a large roll of the awa shima that was returned. the line was breaking very easily.
allowed me to test it and it snapped without much effort.
was probably from a bad batch.
