Braid is thinner than mono of the same breaking strain, which allow you to spool more meters onto your reel.
Personally, i only put Double X hi-viz line on, .52mm, 19.55kg. It is a brilliant line, in my opinion.
If your reel is big enough, you can get enough mono on, or so i thought.
In March, my Fathom 40 was run almost empty, I was getting worried, but then the hook broke due to the constant strain.
That made me decide to also use braid backing now, because it would be a tragedy if a monster make you run out of line.
As for leader, personally I dont tie a leader, if you work your fish careful enough, you can get it out (surf). If you fish sharp rocks, a thicker leader helps against getting cut off.
