Where to look for bass at Inanda
-dave
Another question from a relative newbie again.
When fishing for Bass at Inanda, launching my 2 man inflatable from the picnic area, should I be heading downstream towards the dam wall and deeper water, or should I be heading upstream away from the dam.
Last week we had some good fishing in a cove/bay about 2km upstream from the picnic area and now I'm considering heading downstream to see how things are closer to the dam wall, so any advice/warnings/tips would be great before I head out.
Bear in mind that I'm only using a 30lb sneaker motor, so any spots too far away aren't a good idea (in case the battery goes flat).
-dave
Bumpity-bump.
C'mon guys... any tips on decent spots where I should be looking for bass at Inanda?
dario
As you head into the dam area launch from the first slipway on your right.Head out stright until the other side then turn right.Go for about 300m and you will find a rocky area.Move out around 20m from the shore and cast into the deep water.Trol in slowly towards where your at bumping it up the rocky ledges towards the shore.I caught three fish in about 15 mins weighing around 2kg using worms.Try is out.Good luck and tight lines.
