Where do you get it or how does one make that tube
fisher
Where do you get it or how does one make that tube thingy that some people use when pumping prawns?
You know the tube with the net that the sand gets pumped on so that the prawn can't swim away.
It looks easy enough to make.
Sylvester
Banned
The net is easy and cheap to make.....take a pool hose, single section, and turn it back on itself to form the tube. You can secure with a reasoble adhesive. Then cut a piece of shade cloth to cover the one side of the ring. Make sure you cut the circle of shade clothe big enough to fold up the sides of the ring and back in. Then get some normal polyester or nylon cord and bind the net to the ring in a spiral pattern (thread the cord through the holes in the shade cloth as you work your way round the ring....voila a net for pumping prawns. Mine works like a charm and has not brocken down in any way as the pool hose is designed to handle sunlight and water and so is the shade cloth!
Koeks
2 ways try some high density foam, and glue some shade cloth a a fine mettal mesh to the bottom, or make a wodden box, use a staple gun and staple shadecloth to the bottom, then to make it float attach a 2l coke bottle to each side of the square, use cable ties, works very well aswell.
On_Dad
Don't forget the "venter" to carry all that
Patrick
Yeah you can buy one from Sportsmans warehouse or most tackle shops. i made mine but the mesh kept losing its taughtness. Found it better to buy one instead.
