raggie hunter
Where can I get hold of the rulings for 2008/2009 season?
Still allowed to slide in the Western Cape AFAIK - the southern or eastern cape has banned sliding from their league comps.Raggie... most Associations make their own rules within the framework of the National rules... eg: I think (stand to be corrected) Western Cape have banned sliding for league this year, while KZN are sticking with it...?
Extract from SASAA Agm meeting in Jul 08 in PE ...
"21.2 SLIDERS
The following proposal from W.P. is accepted:
Barbless hooks must be used. Proposal for a slider trace. The objective is not to have a sinker break off as this will increase the possibility of the anglers line wrapping around the fish. The proposed slider trace consists of a 1 mm leader, tied onto ± 700mm 120lb steel and the slider sinker tied directly onto the steel. The hook trace consisted of a slider mechanism with two 10° Barbless hooks joined onto ± 400mm 120lb steel. The logic behind the trace is that once the shark took the bait the sinker would actually travel with the fish. As soon as the fish is identified as a Great White the line must be cut. This will result in the sinker dropping to the sea bed and the line pulling out of the sliders coil. The conventional method is to have a much weaker line between the slider stopper and the sinker. During a hook up the weaker sinker line breaks, the sinker falls away and there is no means for the line to part from the Great White "
Hiya Trophy, just a quick question. In your experience, where do most of the burn off's occur. At the ring or on the main of the 1mm leader?[color=#006600]Kumz[/color] wrote:Extract from SASAA Agm meeting in Jul 08 in PE ...
"21.2 SLIDERS
Hiya Kumz, I recently had a very long chat with a local PE and Springbok angler about this proposal.
My question and this is if I understand the rig corectly. When you have a length of steel 700mm long passing through the coils under tension it causes a spring effect to the steel. I currently use about 250mm of 200lbs steel from my leader to the stopper ring and everytime I land a fish the steel coils so badly that it would not easily pass backward through sliders coil. (Possibly 5 of 10 times) Would 700mm not just increase the coils and decrease the chances of the line slipping through the slider coils.
Now by adding the 8 - 10 oz sinker to the rig with steel you could end up with the fish towing meters of topshot, meters of 1mm leader and 700mm of steel attached to a 10oz grab sinker.
Never mind the line or leader snagging or being wrapped around the fish, but imagine the sinker being snagged on a rock surface. and the fish being pegged down by 150 Lbs steel!
Is it just me or am I missing something!?!
Hiya Karma,
I think Habib posted a thread on how to get a slide down to the stopper. I recon that most of the time the slide never reaches the stopper. I don't suffer may burn off's and when it has happened I recon that it was the result of the silde getting tangled with the main either on the topshot or leader.
What did you think of my concerns on the proposed sliding rig?
Hi Trophy
The steel tied to the ring very seldom however display the 'pigtails' you describe
Hey Trophy
Smoothounds and Black spotties would have a tendency to roll up the line, so to speak, at or near landing hence the pigtail effect.
