When lifting/lowering I noticed that my one engine
CAT STEVEN`S
When lifting/lowering I noticed that my one engine would occasionally stick in a certain position, even though you can hear the hydraulic pump running. I checked and the oil level was quite low, (there are no visible leaks). I topped it up with auto transmission fluid (ATF). Now after a few months the same problem again. Is this oil too thin perhaps?
Pro-Duck
Fill it up, tilt the motor to the top and then doen to the bottom. Fill the level again, repeat the up and down tilt twice. make sure of the level and hopefully its sorted.
FLUKE
ATF is Ok, Hydraulics is my business and air can cause a lot of problems. Priming it should sort it out but remember if the oil is low it HAD to leak out somewhere. It might only be leaking when the motor is under power as this is when the cylinder is holding the most load. Watch your trim gauge, if it's really bad you might even notice that on a long trip the motor gradually trims back by itself. This is only one of a few ways it could be affected.
Always fill it with the motor down or else you will overfill it.
CAT STEVEN`S
OK, so i couldnt wait. I lifted the motor, undid the large plastic screw and filled it. It took about 60ml. I then tilted it all the way down and then up again- oil did come out during this, which clearly had air in it. I put in another 40ml or so and repeated the process. Finally i filled it with about 20ml. My question is: How do you fill it with the motor down as you cannot access the fill hole, and what if it is overfull? It seems to be working 100% now.
Many thanks for the valuable input and advice guys!
FLUKE
Great, maybe they put the filler at a lower point to compensate for the fact that the cylinder is extended when filling up.
CAT STEVEN`S
I think you are correct, as i phoned my local boat shop and asked the guy i always chat to, and he said to fill it with the motor all the way up. Anyway all is well that ends well. thanks again!
