When all else Fails ...
Def-e-nition
Ok , so seeing as Though the Knot section is  locked up tighter than paris hilton On a Marijuana charge , I Thought I'd post up a tip for thos ewanting to use the Knot , but sometimes having it fail .
 after Reading my post , i was tempted to Never use the Knot again , as It cost Me possibly a perfect landing for a Nice size Bronzie , off kleinbrak , Last Weekend  .
So i went and did a little bit of what Julius Malema should do: I sat and did a bit Of Thinking ...
An allbright Knot is , possibly , one of The strongest Knots pound for pound , that you could use to tie a Section of steel onto the front of your Leader . One Does this , again , in order to Prevent the slide from biting Onto , into , or Through the , leader , in a Diameter of , say ...1.2 -1.4mm Leaders .
Now . In order for this to work , in order for This to help you land your prize Catch , you have to MAKE SURE THE KNOT YOU USE TO TIE ON the Steel in the first place , doesn't COME LOOSE !!
I went and Thought what I possibly did wrong that fateful Morning . I'd tied the Knot 2 times , before finally settling on , but Not happy with , my allbright . I'd Made This knot countless times before , but Never before using 210Lb steel .Bit of over-kill , really .
Anyway .this is What I've found , and IS possibly the Only single reason Why your Knot would've failed , as Mine did .Here goes :
I normally am useless on the beach , so in order to Prevent myself looking like a fool , I pretty Much pre-make as Much as possible .Even when i go fishing for elf , i Pre-make and Knot up  some 4/0 hooks onto light steel , and then i bend the end of the steel bit , ready for tying up the famous allbright . been doing this for a long time .
On that fateful morning , I'd decided on a piece of Steel , for "just in case" .This is where i Let Myself down .
The allbright works on a Pinch principal: The tag end is literally Pinched up into the corner of the Steel (friction), by means of turns made on the Steel Leader itself , with the Mono.
On this Particular Morning , I'd pre-made this Steel bit , but not made provision for tying the allbright with1.2mm Line , and this resulted in the tag end of the Steel being too short .I then Opend the Steel , re-bent it (take Note) , and proceeded to tie up my allbright .
The Steel looked something like this :
Def-e-nition
The two Kinks Were closer together : basically I'd Lost the Plot a little , and lengthened the tag end to accommodate the thicker 1.2mm Mono .
The Results Were disastrous .
For an allbright to work , one needs to create a slot, that Narrows the harder one Pulls on the Mono .When you Kink the wire , this does not happen , and the Line tightens up on the first Kink , leaving the slot far too Big to ever pinch the Mono , and the kink prevents the Knot from Ever closing properly ,even after i Punished it On the Beach Before whacking it out .Never in a month of sundays will it pull itself closed , Never . Not Even with a 120+kg fish on the end .I realized this when i pulled it on the beach , and it sort of almost , well kinda, Maybe , felt a bit dodgey . When i got the fish on , the first Thing i Thought was: shucks , Sheldon -I hope that damn knot holds .........Which , of course , it didn't .
I've Exaggerrated the distance betweent he two kinks I'd Made, but the Over-riding message should be clear: if youre Knot ever Fails , this will and can Be The Number One Reason for it's failure .In a sinlge stupid Moment on the beach , I'd ensured that i Lose , YET ANOTHER , good fish .
On the right I asked my 5 year old son to show you  what your'e steel should Look like . ALways leave a longer Tag end , and do Not , as i did , make it too short , so short that you have to Re-bend the steel , as you will invariably be sorry for being so Snoep with the Steel . One single Knot , and it cost me a prize fish  .
I hope This helps at Least someone Not to Lose their fish , all because the allbright Knot failed .
neilg
U dont need steel man
And if u really want steel , why not try a thimble ?
Or a steel wind-on ?
Albright isnt that small anyway
Def-e-nition
Yea you right , it's Not thast small Anyway , but i used thinner Steel , 135 Lb , on Friday Moring , and It worked Like a bomb .
 I'd Kinked the wire and When i Re-kinked it , there's where i Made the Mishhhhtake ...
Thimbles are really Nice , and is One Thing i would Definitely use if i was tying 1.4 mm Onto a small stopper .For sure . we dont get em here , unfortunately , Neil.
I found some monster Stoppers , but at R5 a pop and Me going through slides Faster than Britney goes through Men , I'm afraid that's a little Expensive ..It does Work , though , and being Thicker I Feel Much safer in the Knowledge you aren't going to lose a fish due to the stopper Cutting through the leader .
 Pressure is a bugger , and can easily casue tackle Failure there ...
 Just ask hannes , Who Lost his Pb cuz the Stopper worked wonders on his thin Leader .
 The Knot he tied slipped and slipped , and bye bye ..
I've had to lose 5 bloody fish to finally work through my errors , and NOt let Excitement and eagerness , get the better of Me ..
If I may sound stupendously stupid in asking this, then I beg your pardon.
What about two figure of eights with the steel and windon?
