Hi Barbelman
If the carp are used to small food items then they might take abit longer to pick up a big boilie. But really anything up to 20mm shouldnt be a problem for even 5kg+ sized carp. Some years ago I experimented with boilies up to 30mm and even then I still had 8kg carp pick it up. It will for sure keep the smaller carp away but its not necessarily just for 10kg+ carp.
Instead if I was you I would use a good allround feed mix containing particles and whole+crushed boilies matching the boilie you want to fish on the rig, create a nice carpet of feed, and build the spot up get the carp feeding confidently and then just fish with boilies until you start getting the bigger carp. Stick with 20mm and see how it goes. The ratio of big to small carp is also a factor and if most carp are smaller then targeting the bigger ones become more difficult.
Alternatively if you want to try something different, look at using the hinged stiff rig with a good very bouyant 15mm white or pink pop-up. Its a brilliant rig and generally seem to produce the bigger more weary carp. Worth a try for sure.
