What Rod
rocknsurf
Hi guys, I am busy looking for a new spinning rod
Ideally I am after an 11 ft , 3 piece rod that can comfortably cast lures ( plugs/ spoons) between 2 to 3 ounces range. I prefer a slimmer design blank with a short butt end.
I have been looking at the Assassin range because I have a soft spot for these rods,
But what else is out there?
Budget wise I am looking up to R2k, but at this stage price is not my main focus so if its more or less than that I dont mind
G
Guest
Guest
What fish will you be targeting.
What lbs braid will you be using
What reel will you be pairing it with
Will you be fishing from ledges or the beach
This detail will help greatly in providing you with advice.
rocknsurf
Haakies wrote:
What fish will you be targeting.- mainly yellow tail , Garrick and the likes
What lbs braid will you be using - 30 lb
What reel will you be pairing it with - will decide that when I have selected the rod
Will you be fishing from ledges or the beach - mainly ledges and rocky points
That braid is too light, even for the smaller tail, right for the garrick though. Best to have a heavier outfit and also a medium/light outfit.. From the rocky points you can go shorter, that 10ft exage/stradic combo that was up for sale would have been perfect for the cape.. I have my lighter exceller 10'/9'6 stradic 5000/30lb garrick setup which has landed a few tail in the cape but if a big tail grabs me i'm in trouble. For that I have my other stick to stand a chance. But if a leerie grabs me on that rig it stands no chance so hence a lighter setup for some sport.
G
Guest
Guest
In the 11ft range - look at the Assassin Sierra XH. Perfect for 30lbs paired with a 5000/6000size shimano.
It is 2 piece and a fantastic rod. I own the 2xh and my next rod will be the xh.
It is a little outside of your budget but I can assure you it is worth it.
Our current rate of exchange has just ruled out importing rods. Majorcraft make a number of reasonably priced (in USD) rods that would be perfect for our application and some in 3 piece.
At 10ft a very popular ytail rod is the old model 10ft Exage.
The other Assassin rod you may look at is the Kob special.
Something to consider would be chatting to Enigma about a custom Sensation DC oval rod. He can alter the 12 ft blank to make a very nice 11ft rod. But again 2 piece.
Be careful of a rod that is too stiff at 11ft. Fishing off ledges can be a problem if you get your rod angles wrong - you will see breakages, especially if you intend lifting fish. This is why i like the Sierra. The construction composite is very forgiving and should take the rigours of this sort of fishing.
Kind regards
Anton
i-fish
I completely second Haaikies here. I just got myself the xheavy Sierra. Expensive but awesome. Rated 1-3oz. Chasing big yellowtail only, I will get the 2xh Sierra for sure. Or, on a budget, the Kob special
rocknsurf
Thanks for the inputs guys
seems I may need a re think
I already have a lighter, 10 ft set up that works well as well as a 12 ft heavier rig, but I am finding this a bit too much on my arms when I fish for longer periods,
hence me looking for an 11 ft rod
will take all the comments on board and give it a re think
cheers again for the inputs
noclue
The list in your range is huge actually.
Penn Regiment
Sensation Pro
Sensation DC Oval
Berkley Venom or Taipan
Shimano Aerocast
Shimano Tiralejo (9ft)
Assasssin Spin Master
Asssassin Kob Special
Dawia Exceler
Daiwa Saltist
Daiwa Exceler Elite
Asssassin Amia
Assassin Sierra
Waft
Think thats what I have looked at, and am more undecided than before
Good luck
rocknsurf
Wow, talk about undecided I now have no clue at all Noclue..thanks
back to the drawing board for sure after that message.
:shock::shock:
noclue
:shock::shock:
My mind was made up for me yesterday. Got an awesome deal on an Assassin Spin Master, so I'm done looking! Good luck with your choices!
rocknsurf
Hi Noclue, out of interest what model did you get in the end and what was the damage? be interesting to see price comparison here in Cape Town
noclue
Hi RocknSurf
Sorry, for some reason I only saw your reply now. I got the XH, rated 50-150g.
Its a beautiful rod, but not the right rod for regular use, too heavy!
