What line to use?
esatpil
Hi Guys,
Need some advice on what line would be best on Stella 4000FD for dropshot.
Im pairing it with the Berkley Air 9ft.
I was thinking Fireline 20 pound but would like to hear from the others.
esatpil
I will go the 20 pound since I will be drop shotting of rocky areas in Durbs and then the surf zone.
Do any of you drop shotters out there use full braid for dropshotting?
esatpil
Reason I ask,after reading Reefmans explanation of Fireline,it is clear that Fireline is not a braid like Whiplash.
Nepptune
Nice rig Esatpil..... you certainly are building up a very nice collection of tackle my friend!!!Awesome!!
I'd go with full braid in minimum 20 lb.... I'm not gonna go into which brand as the merits and tech of each one has been debated and posted time and again on here....
But spend wisely and you will get PLENTY of good times out of that set up...
ignoblis
esatpil
I have a daiwa exeller 2500 spooled fully with 6 pound Fireline and on the other spool I have 15 Pound Mustad Dynamite ultrabraid the stuff is so thin that my 2500 has more than 250m spooled on it. The 15 Pound is only 0.08mm in diameter and 19 Pound is 0.1mm. Super thin. Check it out.
ignoblis
esatpil
Hey Nepptune,
Yeah Im getting there man,since you know Paul from Luckys when you see him he will tell you I am one of biggest customers in recent times.
esatpil
[color=#006600]ignoblis[/color] wrote:
esatpil
ignoblis
Hows the casting with the Mustad Ultrabraid,is is not too light for windier conditions?
ignoblis
esa
I had some problems at first as I fillled the spool with the entire 270m of line.
After removing 20 metres it has been fine. In fact I only recently took the line off and was trying out my new Daiwa exeller 7" Medium Heavy Fast Action rod this week end in the howling wind and rain and the mustad braid was great.
No wind tangles as in the past.
ignoblis
esatpil
Hey Keane,
Im not from PS,but all my wifes family is,that how I was introduced to Luckys in PS.
I go there often when I am down.
munoo
I also have 8lb fireline on one of my reels and 19lb mustad braid on another . The Mustad is good ,very strong, thin and haven't had a tangle when casting . It however does'nt cast as good as fireline  . I'd go for fireline . I also noticed today that a few tackle shops sell them by the metre and can have the braid spooled for you - does work out cheaper .
I am currently using 10lb ande braid on my 2500i coffeegrinder...works a charm...caught a couple off shad and a 1.3kg grunter on it so far while fishing off the pier on drift bait..its a feeling that cannot be replicated by any other form off fishing!
got 30lb braid on my penn 6000, waiting in angst to give that a try..will definately have the set up fully ready by the time off our durnford trip,will give fool feedback thereafter...
neilg
When you spool soft braid load as tight as possible onto spool, and I really mean it, if it is not done properly braid will cut into itself, and you will lose fish and line. that goes for any reels and any soft braid.
in that regard I think it's better to have a shop load it for you (if they have the right machine).
Fireline doesn't have to be loaded as tight.
ps Esatpil, nice reel ... gelukkige bliks%m
GL
[color=#006600]esatpil[/color] wrote:
Hi Guys,
That's an awesome setup there. I use 14 and 20lb fireline and will stick with this combo.
Is the stella 4000 FA the new model and spool shape that lets you cast bit further?
esatpil
Hi GL,
Not sure what the FA looks like,but the one I am getting it the 4000FD.
Heres a picture,perhaps you can see the difference.
GL
Cool, that's the latest model.
Pre 2008 models (RA) had the spool that had a flat top like a "T Junction" so when you cast, you got less distance as it is not as streamlined as FD. small thing but makes a big difference i reckon of about 15-20m!
