K, now here's (not necessarily) another spanner in the works, if you've ever done sight fishing in clear and shallow water with something like a Strike pro Minnow, you'll actually see them fighting to get the lure first, i've had instances where the first three would strike the lure and miss it only to have th fourth or fith one holding it long enough for me to set the hook.
So to the schooling theory I give it the OK, and believe me, when you smack a school like that you're bound to get results like 35 fish in a hour and a 1/2, they might be smallish, but never ever underestimate the power of the darkside, there's almost always some two or three keepers trailling if not in the school themselves, (the darkside= they just waiting for a small one to get hooked and start struggling then their darksides comes into play and they attack the small ones)
Structure fishing might (probably is) way different as when (like VC said) they guard their structural teritory you might only get one or two from that piece of structure, that I was also able to see during the low water levels that the Plaat recently had experienced so like Loams said, cast rihgt back to the same spot until they stop striking or smacking your lure, then and then only change the location of where you cast, also remember to work methodically in you hunt (fan casting with no more than 30cm's between places where you last casted, csat in the new location again a couple of times and then move it again something like 30cms' and so forth.
Oh and when you change lures start from the very fisrt spot again...... you never know what the lunker in the first spot wanted for breakfast and perhaps it's the new lure you just tied on.
