what diameter leader should be used?
Gees likes! Wat kinda help is that leonard? Why not jus give the man a 5inch thick steel cable an tell him use that incase he hooks a killer whale!!!!!!!!!!
Darren, the smarter thing to do would be have a range off leaders from 0.5mm thru to 1.mm.. Then depending on where u fishing an wat u aim 2 target change your leader accordingly...remember 2 fish as light as possible if fishin edibles because they typically fussy feeders...
leonard williams
im saying use 1mm arati leader line.the same as what hennie papenfuss uses.its better to go heavy,and if you scratching for small stuff amongst the rocks i also use a 1mm,incase a cracker picks you up,hell cut you off on the rocks.
jace
Hi guys
Quick question?
Must a leader alwways be a floro-carbon...because Kingfisher sells a line that I think is not Floro-carbon but is called a leader???
Rdgs
Jace
Riymos
Banned
Howzit Jace
From my experience i have come to know that Floro Carbin is alot more expensive then regular leader line so to say.In fact it is almost 4 times more expensive.There are however a few advantages of floro.
1.It is very very abrasive resistant in comparison to regualar Kingfisher Leader.
2.It is also almost totaly invisible under water.
3.It also has alot less give then you have in most common leaders on the market.
I for one most of the time us ethe Kingfisher or previously the Araty leader that the Kingfisher used to sell.I now see that they probably managed to find a less expensive leader which they obviously branded there own and thus now sell the KIngfisher leader.The reason i use this leader is because of the price.
If you fish socially then i dont see the need to really go through the epense of using this expensive leader,but hey if you can afford it then i say go for the best.If you are fishing competitvely the yes every litt;e factor plays a roll in sucess and failure so in that case i would say use only the best leader in order for you to not to have a loss and also optimise you sucess rate.
There are probably a few who may disagree with me saying that you have to always optimise you sucess rate but you have to think realisticaly how many of us can afford to spend that amount on leader and then loose your whole leader twice in one outing by getting stuck in the bricks or tangling in some owes line or even casting it of.Those are the factors which steer me to using what is affordable for a specific purpose..
Cheers Riymos
Flurocarbon is expensive because off the composition off the line..for social fishing either kingfisher or araty or speedspin is good stuff..cost effective to loose thru wear an tear an trace line,but if u fishing competitively then go for the best,
the advantages off flurocarbon far outweighs the price..u can now use a thinner leader for the same application which has better feel when u get a bite,the line is less affected in a sidewash,flurocarbon bein almost if not invisible in water and finally a thinner leader gives u a marginally better cast (because u got a smaller fig 8 an bimmini twist) an all that makes a huge diff when u in a timed competition...i hope all this techno jargon helps but above all jus "keep it simple!"
jace
hI GUYS
Thank for the info as the guys in the tackle shops tend to confuse the hell out you...I have ended up in the recents months buying on impulse. I have now learnt that I post queries on the forum first before going tackle shops.
This is what makes the forum Special.
Have a good fishing weekend.
rdgs
jace
leonard williams
no it doesnt make a difference,they were still catching fish in the old days with green maxima,but it makes it more invisible.arati is good for the price it sells
Jace bru
There is absolutely no reason to use Fluorocarbon for your entire leader. Use ordinary leader from mainline to swivel... then from swivel to HOOK (Hook snoot) use Fluorocarbon. Only your bait needs to be on invisible line... So 1m of Fluorocarbon per trace makes the FC last a long time.
Noweeds
80% of the time i use 1mm araty, they are now no longer importing this line so i will have to find a replacement. I use 1.2mm perlon for all my heavier fishing. I will will go down to .80mm if i am fishing for relly fussy edibles.
Dorsal Fin
If you are not sure what diameter to use follow these simple tips and as you learn more you will be come confident what to use when.
Edible fish: Remember that for edibles you need to fish as light as possible for the specie you are targeting. Start with a 0.70mm Maxima Ultragreen, this is ok for most edibles.
Sharks and Rays: From a 0.90mm to 1.20mm is sufficient in most situations.
Clip or slide: the same as for sharks and rays.
Just remember that when fish are skittish to feed a lighter setup is always better than the block and tackle setup. When you get a pull only to be dropped shortly there after it is a good indication that you need to step down a bit.
When you get hammered and smashed on 1.0mm & 1.20mm then all I can say is, try again and good luck!
Chris1
 The master assasin
Hi
I use a 1mm leader when I'm sliding, but the last time, my leader broke of at the tip 3 times. lost 3 grabnal sinkers. A bit expensive !!
I use a LOOMIS 14' and this eyes is size 12. Now is't the leader to thick for that sieze eyes ? Do i need to go to . 8 orr change the eyes to size 16 ?
I would appreciat some advice from anyone please.
Chris
Hi chris...firstly i do not know wat method you use to attach your leader to your mainline so i cant comment on your leader snapping,remember MOST leader line's out there are not so tolerant to nick's and grazes and should be replaced frequently enough...
regarding your 12mm guides, they should be ample enough to handle 0.7 to 0.8mm but using 1.0mm and higher is definately a no no! U will hear and feel the leader knot knocking thru each guide as you cast, if u have the funds avail then change the eyes on rod to 16mm with the flip guide...the difference is literally night and day! And finally..dont discard the strength off something like 0.8mm leader,if u not fishing on rocky outcrops then it will handle most off wat the ocean has to throw at you...i hope this helps, let me know if i can help a little more...
