What Braid should I use?
CGD
Hi guys
I've been looking at getting a reel for surf spinning for Kob and leerie and maybe a few yellowtail...
What braid do you guys recommend for surf spinning for those species???
chris ferreira
WITH BRAID I WILL RATHER SPEND A BIT MORE TO GET SOMETHING THAT LASTS I WOULD RECOMMEND BERKLEY WIPLASH OR FIRELINE LIKE AN 20 OR 30LB
frank22
power pro 20 - 30 lb super slick(great line got it on all my reels very strong and can take a beating)
sufix 20lb (a bit stiff but after a few casts and fish it becomes softer)
fins windtamer 20lb (very nice casting for windy areas)
Oelof2014
I would also go with Sufix 832. Very good spinning braid! 30 pound braid with a 50 pound fluorocarbon leader...
frank22
20 - 30 lb braid is a good all rounder line, obviously if you going for bigger game fish you will need bigger reel for stronger line capacity and a sturdier rod to suite this. But if you going for the normal spinning situation of leerie, elf, kob and grunter. 20-30 lb is perfect.
frank22
not a very good line in rocky areas , does not handle abrasion very well , good knot strength but knots do fray and need to be checked after a few casts.
CGD
So what would you recommend?
frank22
Yeah that line is good i have used it alot, a little pricey but good low noise through guides and cuts through water and low water resistance. Also like the 25 metre colour change on it.
CGD
So which is better quality...the Daiwa Saltiga surf or Suffix 832? Which one will last longer, be more abrasion resistant etc.
frank22
gator braid is a good line to but it is a slow sinking line which means it is prone to accepting water and gets heavier , i have had gator braid become water logged and have to unspool it and leave it in the sun after every session.
many factors in buying braid but so far i have been happiest with power pro super slick 8 , sufix 832 and daiwa saltiga and samurai lines.
so the choice is really yours at the end of the day , all my reels except 2 have power pro super slick on and never had issues with the line. have to realise braided line just means more sensetivity , no stretch and more line on a reel. it still snaps , gets tangles (sometimes) and wears through on rocks just like monofilament or florocarbon lines.
riekert
GOSEN - cannot go wrong with it. I had Suffix 832 before the Gosen, and that stuff feels like a rope against the Gosen. I don't even use a casting glove with the 25 lbs Gosen on my reel. Soon I will be changing over to the Gosen Jigging braid, which is even thinner for the same breaking strain than the standard Gosen.
Jacquesdw
I 2nd riekert. Just spooled a sustain 5000 with the new Gosen Omega braid- PE2.5, 35lb. Used it for 3 sessions now, 2 was into a heavy SE wind going for yellowtail, and no windknots. Superthin, knots easily. The best heavier braid I have used.
I got mine from bigcatch.co.za at R530 a spool. Basil Manning sells for R830 a spool. Get it before they realise their mistake!
riekert
Brilliant thanks! I will take a look into this sommer tomorrow!!
